wolf guard help
tuek2k
A wolf guard who is the last man of my grey hunter unit can capture a target? (sorry for my inglish)
A wolf guard added in a wolf scout unit can use the rule behind the enemy lines?
You can have on the table a wolf gurad unit with less of 3 members?
I'm from Barcelona, thanks, and sorry for my inglish
https://bolterandchainsword.com/topic/181907-wolf-guard-help/
Your english is fine.
1. Yes, Wolf Guard Pack Leaders, once assigned to a squad (at deployment), remain a part of that squad for the remainder of the game.
2. Yes, Wolf Guard Pack Leaders may use OBEL (Operate Behind Enemy Lines).
3. Yes, but only after having assigned them all to other packs. A Wolf Guard Pack (when writing your army list) must still have a minimum of 3 members.
Hope that helps.
DV8
What about dedicated transports assigned to WG after all the WG have assigned to squads? There has been some confusion on this, and I for one am confused. I see no problem with the pack that WG is assigned to loading themselves into the transport, but on the other hand if that's the case then that WG no longer becomes one with that pack singling him out. Almost as if he's an IC, which we all know isn't the case with WG. So does the land raider become an empty tank at the beginning that a WG-led pack can embark?
No, because like you say, the pack is only led by a Wolf Guard.
Only units for which a dedicated transport was purchased for (in this case a Wolf Guard Pack) may deploy in the transport.
When a Wolf Guard is assigned to another pack to be their Pack Leader, the squad designation does not change. A Grey Hunters Pack with an assigned Wolf Guard Pack Leader are still just a Grey Hunters Pack and a Troops choice. A Long Fangs Pack with an assigned Wolf Guard Pack Leader is still just a Long Fangs Pack and a Heavy Support choice.
So were you to purchase a dedicated Land Raider for a Wolf Guard Pack, and then assign all the members of the Wolf Guard Pack to other units, then at the beginning of the game, nothing can deploy in said Land Raider.
In a similar vein, taking Logan Grimnar (who makes Wolf Guard troops), and then assigning Wolf Guard as pack leaders, does NOT change the designation of the squad they are assigned to.
Example:
You have 3 units, Grey Hunters, Swiftclaws, and Long Fangs. All 3 have attached Wolf Guard Pack Leaders, and all are reduced to 1 man (the Pack Leaders).
The Pack Leader assigned to the Grey Hunters counts as part of that squad (Troops), and so he can capture objectives.
The Pack Leader assigned to the Swift Claws, as he is part of the squad, counts as Fast Attack, and so can only contest.
The Pack Leader assigned to the Long Fangs, again as he is part of the squad (Heavy Support), can also only contest.
DV8
