Token Posted October 22, 2009 Share Posted October 22, 2009 How does obel work in a planetstrike battle? Link to comment https://bolterandchainsword.com/topic/182540-obel-and-planetstrike/ Share on other sites More sharing options...
Audun Posted October 22, 2009 Share Posted October 22, 2009 For attackers it should work the same as it always does, with the drop zone as your "table edge" A bit trickier for defenders, but it in the Planetstrike codex it says that "All other defending units roll on the following chart when they enter play from reserve:" in the Wolfdex it says "If a Wolf Scout unit makes use of it's ability to outflank, roll a dice when it enters play to see where it may be deployed" I don't think that outflank exists in Planetstrike (replaced by Scramble?) , so OBEL doesn't seem to be able to be used in 'strike. You could ask to re-roll the dice for the entering edge in friendly games, but if there are competitive 'strike games I don't think you could use it. Link to comment https://bolterandchainsword.com/topic/182540-obel-and-planetstrike/#findComment-2159251 Share on other sites More sharing options...
muzzyman1981 Posted October 22, 2009 Share Posted October 22, 2009 I believe that the Wolf Scouts ability would override the Planetstrike rules. Remember Codexes override pretty much anything, unless there is a statement that says otherwise. If you want to look at it from the fluff side of things for "my way" the Wolf Scouts are more experienced than 'nilla SM scouts so Wolf Scouts would work their way around the enemy to find the best position to attack. Link to comment https://bolterandchainsword.com/topic/182540-obel-and-planetstrike/#findComment-2159427 Share on other sites More sharing options...
