Heresy or Corvus Pattern Shoulders
Iacton Qruze
Like studded shoulderpads? Have a hard time getting any, because they only come in a couple of box sets and cost upwards of $3 a piece at an online bits shop? Maybe I can help.
Alright, here's what you need:
1. a file
2. a pokey thing ( a needle works, but I use the top end of the wooden tool on the left)
3. your super glue of choice
4. a pin vise, and the smallest bit that comes with it.
5. a standard SM shoulderpad
6. glass micro beads, 1mm
for the beads, here's a link to where I got mine. the cost is cheap, there's enough in the bag to do a whole company of pre-heresy marines if you wanted to, and shipping is more reasonable than anywhere else I could find. You do have to make a quick little account though, which is free.
Glass Microbeads
if you find my link takes you to an out of stock listing, keep looking in that same shop and you should find what you need. color isn't important.
Step 1
File the trim from the shoulderpad like so.
Step 2
Take your needle tool and poke guide holes. You might want to identically match existing studded shoulderpads in your army, or create a new design you like. I wanted a few more studs than what is on the plastic shoulderpad.
Step 3
Take you pin vise and drill into your guide holes. not clean through, but just maybe 1/3rd to half-way, like you're making an impact crater from a bolter. If you find a hole doesn't line up with the others, redrill where it looks right; you can come back at the end and clean it up with a tiny bit of greenstuff.
Step 4
Take your glass beads, put a tiny bit of glue in the hole, and drop a bead in it (they're so small, I find it best you lightly lick your finger, and touch one on your table to pick it up. just set it in the hole from there) wipe away any excess glue after each bead. You might get a cleaner job by using a tiny applicator, or failing that, when you have the glass bead sitting on your finger, squeeze your super glue until a little bit is coming out and lightly touch the bead to it, and then set it in the hole. It’s also faster, as I can do 4 beads at a time, instead of going one by one.
Step 5
Use greenstuff to fill in any bad spots, and use your file to smooth any areas that need it, and you're done! Repeat step one on the other shoulder pad, and you have a proper pair of Heresy or Corvus pattern shoulderpads.
  • 2 weeks later...
just ordered me 2 bags of these on ebay. I almost spend more on the post&packaging then the beads themself and I should now have enough to last me my entire modelling career.
This is a great solution/idea so thanks for this!
I also really like the skull/guardsman helmet combo on the test-figure's base :(
A deceptively simple yet brilliant idea!
Got everything apart from the beads - just ordered a 25g bag online for £1.50 including postage. Thats about the same price as Bitz sites are selling the Corvus pattern shoulder pads for anyway!
This method is an absolute bargain in my opinion.
  • 1 year later...
Does anyone know if this shop for the micro beads has just gone out of business or just not selling right now? I went and checked it out but it seems they have 0 items for sale at the moment, does anyone know anywhere else I could get them?
