Team tourney
Drahazar
There is a Team Tourney coming up 750 per person. I am going to use Pure SOBs my team mate will be going Anti Tank ill will go Crowd control. My team mate will either be Tau or IG so I was wondering what I should do to complement his army. I was trying to decide between Mech or foot slogging. What are you guys suggestions and thoughts on that and what not. Last time the winner was a Ork Tau combo which was pretty nasty stupid shield generator. Anyway do I go Mech with ret support or Foot slogging with Ret support and seraphim. Must follow FOC and allows Special characters.
https://bolterandchainsword.com/topic/182779-team-tourney/
If you're going to be doing a gun-line army, forget the mech and mass sisters. Quite honestly, mass bolter fire is deadly. If you're worried about CC (I would be) take a unit of Repentia w/ Priest and hold them in reserves. You could get a decent size squad of Repentia w/ 2 big sister mobs in 750, with a cheap Cannoness. Repentia coming out of reserves will annihilate whatever they touch, but will probably die thereafter. So, works wonders against a mob of Nobs or Termies that gets to your lines.
Keep in mind their I1 - work best vs other I1 models like TH/SS Termies or Klaw Nobs.
https://bolterandchainsword.com/topic/182779-team-tourney/#findComment-2163106
oh god. repenentia.... now they will not get out of reservs and kill stuff . not with 1A each base [2 for charging] hiting on +4 and I1. do the math against a 10 man of csm or even tacticals . you would have to run 14+models for it to work[also a no hq may join repentia , so no canoness].
as team tournaments go . there is no such thing as I go short range shoty and my friend goes long range . you both build the same list. He spams hammer heads +suits . you spam exorcists . he goes mecha , you go mecha too . two armies that use the same tactic will always work better then two armies that use different ones.
https://bolterandchainsword.com/topic/182779-team-tourney/#findComment-2164013
