Chaos Dread Head dilema
YO!
I have recently picked up a loyalist dreadnought with hopes of converting it to chaos because, in my mind, it is easier then shooting myself later for buying the ugly current one.
so far i have built a plasma cannon arm and am working on creating the torso to resemble the MK IV ones over at FW.
this is where i have hit my first roadblock, i put the torso from a terminator onto the front (where the plate with the eagle and vision slot thing normally are)
but i cant figure out what kind of head to use or how to position it. Regular helmets are too small and the head im working on using greenstuff is kind of uneven.
Im trying to avoid it looking like a regular marine with GIANT shoulders and arms.
My other problem is with my Dccw. I dont want to use the one from the kit as is, i want to make it more of a claw. My idea for this is to use an ork power claw, or just build one that is similar from tyranid claws or blades.
Im not really set on what to do for the head, and Im looking for a way of making the claw out of blades.
Any Ideas??
I cant post any pics until i find my camera... :)
also, if anyone has already done a conversion like this, could u post some pics?! I want to see what others have done, thx!
https://bolterandchainsword.com/topic/182824-chaos-dread-head-dilema/
, I did see that one before. it gave me the idea to use the termie chest, i didnt follow it exactly though..... you will be able to tell in the pics
i found my camera too, and was able to take a few shots
I apologize for the poor lighting, but i dont have a lamp small enough to carry around :rolleyes:
well anyway, here is the sculpted head, still very WIP
here is a side view
the dread with the rim thingie to go above what ever head i finally use
and the regular csm head i found
Does the Head need to be raised up a little bit?
Grab the armor segments (pieces that look like single armor plates with things like spikes or symbols on them) from the chaos vehicle packs and use that to cover where the faceplate on the loyalist dread usually goes. That will keep you from having a big hole behind your head. As an added touch, the face peeling out from the metal works as a good "trapped soul" faceplate.
Example: http://nurgle.muschamp.ca/Models/toeJamFront.JPG
On my AoBR Dreadnought I took the knives from a box of Chaos Space Marines, cut off the handles, and stuck the blades on the regular DDCW. Though on the "top finger" I took a large hook I found in the box oc Chaos Space Marines (can't remember what the bit was specifically) and stuck it on there so it had an oversized claw and smaller sharp claws. Looks semi-decent.
Go to LGS and buy a cheap dargon/daemon/monster looking thing that's at least simular size to dread (or you could buy a dragon or something simular from WHFB off e-bay. use the arm for the DCCW, use GS to mke shoulder & back/chest muscles so it looks like the dread is morphing into a daemon. That's what I did w/ mine & it looks quite good (When I did it you could bitz buy a dragon claw from WHFB though). Use the head from the beasty as the draeds head, again GS neck/shoulder muscles.
Or if you've ever bought a defiler, the skull face plate looks like it it would be about right size for dread.
I just started my 2nd dread conversion last night (1st one with the WHFB dragon claw was done years ago).
I think I have another (different) dragon claw around here somewhere, and I'm going to try the skull face plate from defiler as head.
Mine are the old metal chaos dreads, but they are (will be) so heavily converted that the old metal dread wks fine as a base.
I like the idea of the dragon claw as an arm!
My GS skills are not really up to par to make muscles though.....
I will be getting a defiler sometime soon so I will try the skull mask as a head!
but I think I found something to use as a head with more of a mechanical, robust look to it. the smoke launcher from the Rhino (I forgot to attach)
seems to fit the size of the dread, the tubes being sensors and eyes It even covers up a good part of the hole behind it!
As for the Armor plates from the chaos vehicle sprue, I was planning on using them to represent extra armor
Thanks for the advice!
You could mix and match the parts from the Ironclad kit for different CCW. Or purchase one from Forgeworld. As for the gap above the head, try using greenstuff to make a tentacle or two coming out. Or use the tentacle part provided in the terminator box. I personally used the parts shown in the following links.
http://www.bitzbox.co.uk/images/chaos_vehi...aster_large.jpg
http://www.bitzbox.co.uk/images/chaos_vehicle_hook_large.jpg
I mounted the dirge caster above the hook and it looks pretty decent. I don't have the model with me and I don't have any pictures so I can't provide any further help.
JG
If it can help you, here is mine:
http://img36.imageshack.us/img36/4569/40k249.jpg
http://img11.imageshack.us/img11/9940/dreadface.jpg
In my case I wanted a small head. I've seen dreads with defiler head and they appeared to big for me. So I went for a normal CSM torso/head.
The second CCW is made with... obliterator weapon sprues + other bitz/sprue ;)
Wow! yours turned out really cool!
hahaha whats wrong with tentacles?!
anyway, I got a sarcophagus done (without a head) so you can see the space im trying too fill
here
now with the smoke launcher as a head (not done with it)
now with the horned head again
I still havent purchased a defiler yet, so i might not be able to take that route :(
Alrighty then, horns it is!
perhaps a little GS to add to the size...
I really, really, don't mean any offense by this...but I've seen your GS work, don't GS anything (until you practice some, and get more skilled). Unless it's just to make a "neck" raising the head up higher to fill some of the void space. But really the void space kinda gives it an "empty shell, possessed by a daemon" kinda look, that kinda wks.
