Logan + Long Fangs + Assault
Rindaris
So I've actually been toying with the idea of fielding them in a LR crusader instead. Provides less total KPs and I think it'll work just as well. And I can avoid the whole debate of when Logans power kicks in.
Just why have the Long Fangs go into HtH though? Well, between Logans 6 attacks on the charge, and the WGs 3, not much else should even be alive. The Long Fangs can mop them up (ideally) and thus still provide support to their Lord. I have had ALOT of bad luck in the past when separating my HQ from his squad and then him being targeted and taken out. Granted Logan would be AlOT harder to take out then just about any other HQ, still... knowing my luck, its best to keep him in a squad. Might give the LF squad leader a power weapon just for added ooph.. though I don't know if I could work that in the points.
This is so ass-backward; why in Russ' name are you trying to make an assault unit out of the only pack in the codex that is intended to stay out of close combat? If you want a unit to assault with Logan, take either Blood Claws, Grey Hunters, or Wolf Guard; let the Long Fangs provide heavy support somewhere like they are supposed to.
V
I'm merely considering options and possibilities. I really don't want them to have to assault, but I want to make sure its possible. if I run them with full melta they are gonna have to be close to the opponent to make full use of those weapons.
