First tourny since new Dex
PhoenixFlame
This is my first local tournament since the new Wolf Dex showed up so I'll be detailing a battle report as it happens in hopes my fellow generals can derive some use from it. The format of the competition is as follows. (please feel free to make any comments/ask for any details that seem pertinent to you)
4 matches, one per week starting the 31st (I will update with results and details as each game concludes)
Our point limit was 2000 points with the addition limitation that no more than 500 points each could be spent in the following selections: HQ, Elite, Fast Attack, Heavy Support
Additionally no less than 800 points could be spent on our Troop selections.
All games are played over eight turns and deployment/scenario is determined by dice roll from the following options
1. Seize Ground; 5 Objectives placed in the same configuration as pips on a dice (one in each quarter and one in the center.
Deployment Pitched Battle.
Scoring: Each objective held 4 points, each objective contested with a scoring unit 2 points.
Ties to be decided via Victory points.
2. Capture and Control, as per BRB
Deployment: Dawn of War
Scoring: each objective held is worth 10 points, each contested with a scoring unit is worth 5.
Ties decided by Victory Points
3. Annihilation
Deployment: Spearhead
Scoring: 1 point for every 100 Victory Points of your opponents list you've destroyed.
4. Seize Ground: 3 Objectives, one in the center two in unoccupied table conerners
Deployment: Diagonal
Scoring: 8 points for holding the center objective, 6 points for holding either corner and 1/2 points for any objective contested with a scoring unit.
5-6 Reroll
Army List
List Total: 1997 pts
All point totals listed in { } are total values for that selection type (ie troops, HQ, etc.)
All Point totals listed in [ ] are total values for that Unit
HQ {275}
Logan ~ 275
Troops {832}
Squads:
1. First Squad [260]
1x Wolf Guard w/ Heavy Flamer, Power Fist & Terminator Armor
1x Wolf Guard w/ x2 Wolf Claws & Terminator Armor
1x Wolf Guard w/ Storm bolter, Chain fist & Terminator Armor
1x Wolf Guard w/ Storm bolter, Power Weapon & Terminator Armor
2x Wolf Guard w/ Storm Bolter, Frost Sword & Terminator Armor
2. Second Squad [207]
2x Wolf Guard w/ Assultcannon, power fist & Terminator Armor
8x Wolf Guard w/ Close Combat Weapon, Bolt Gun, Frag and Krak Gernades, Power Armor
3. Third Squad [160]
1x Wolf Guard w/ Assultcannon, power fist & Terminator Armor
3x Wolf Guard w/ Close Combat Weapon, Bolt Pistol, Frag and Krak Gernades, Power Armor
1x Wolf Guard w/ Storm Bolter, Power Fist & Terminator Armor
4. Fourth Squad [205]
1x Wolf Guard w/ Assultcannon, Power fist & Terminator Armor
1x Wolf Guard w/ Storm Bolter, Power Weapon & Terminator Armor
1x Wolf Guard w/ Close Combat Weapon, Bolt Pistol, Frag and Krak Gernades, Power Armor
Elite {420}
1. First Elite
Venerable Dreadnought [180]
- Assault Cannon, Dreadnough Close Combat Arm (w/ storm bolter),
Search Light, Smoke Launcher
2. Second Elite
3. Third Elite
Lone Wolf [60]
~Mark of the Wulfen
~Terminator Armor
Heavy {500}
1. First Heavy
Land Raider Crusader [260]
~Stock + Strom Bolter
2. Second Heavy
Long Fangs [165] (240) <-- Parenthetical value includes Razorback transport
~ 1x Squad Leader
~ 2x Long Fangs w/Plasma Cannon
~ 2x Long Fangs w/Lazcannon
~ Razorback dedicated transport [75]
~ Twin Linked Lazcannon
______________________________________________________________________________________
General Battle Doctrine
Deployment
Logan + Squad 1 deploy w/Land Raider slightly off of center
Both Ven Dreads Deploy in flanking positions to the Land Rader
Long Fangs deploy in razorback behind Land Raider
Lone Wolf deploys to the other side of the deployment area
Squads 2-4 deploy behind him
First Turn/General Tactics
Land Raider is there to soak fire and get Logan et al into assault range
Dreadnoughts are there to soak fire
Razorback is mobile anti-armor
Long Fangs stand back and drop blasts / pick off armor or ICs
Logan + 1st Squad dive into a scoring unit, rinse repeat
I expect to lose all of the above force except maybe Long Fangs
Lone Wolf heads down the board edge to mix it up with the first scoring unit or IC he can find and generally mucks up the works, I expect to lose him also (surprise :D )
Squad 3 caps the nearest objective and digs in
Squad 2 moves toward the next nearest objective and digs in (if occupied stays at the edge of firing range and pours fire into anything there
Squad 4 moves up lightly to the inside of the Lone Wolf and supports him waiting for the chance to cap or contest an objective.
Obviously this is a very loose starting method which will be morphed as deployment and each turn unfolds.
Below is the battle report for each round (sections to be filled in as the are completed)
Round 1
Army Faced
Points Scored
Outcome
Summery
Round 2
Army Faced
Points Scored
Outcome
Summery
Round 3
Army Faced
Points Scored
Outcome
Summery
Round 4
Army Faced
Points Scored
Outcome
Summery
Note to Mods: if any of the data here in is deemed too detailed for copyright etc. let me know and I'll be happy to edit this post.
https://bolterandchainsword.com/topic/183164-first-tourny-since-new-dex/
