Chooser of The Slain
Jarl Bloodwolf
Honestly it doesnt matter. use an objective marker. what ever. Njal is differnt though. i would recomnd getting an actual base because his can attack... so the big questin is does he cause the chooser to B2B when he enters in combat? or does Night wing stay where you chose to put him. then just strike at the modle you choose regardless of distance?
There you guys go, trying to think again; it's not necessary to think, just do what tells you to do in the rules.
1. Place a Chooser marker on the table somewhere and use it to deny Infiltrators and help with BS.
2. When Njal is in close combat Nightwing gets to peck at enemy eyes at I5. Don't worry about the fact that Nightwing might be halfway across the table, just pretend he flies over to attack, then flies back to his post if you fel the need to justify it.
V
V
yep.... this is one of those time when you can actually read the codex and do just what it says. i even think that in Njal's entry it states that Nightwing flies down to attack then goes back.
V
this was one of those cases where i was in class, and couldnt just whip out my codex and start flippin through it while my professor was looking at me
it's ok, we forgive you, just don't leave home without you codex again. :P just kidding, tho i do find it funny when i pull mine out at random times, if some one stares, i just say "yes i am a dork" and that usually settles it.
