DeamonHunters Vs. Tau Battle rep
Polaris
To test out the new board I am building my friend and I decided to play a small 500 point-ish game. The army lists went something like..
Deamon Hunters
HQ
BC with psycannon
GKT
GKT
GKT
Troops
5 man IST squad with 2 melta /w Rhino
Heavy
Land Raider Crusader
Tau - I really dont know the units, I am just kinda going by what I was on the board.
1 Broad Side battle suit ( with str 10 ap 1 cannon and smart missles)
1 Broad Side suit with fusion blaster (anti infantry)
10 x kroot
10 x Fire Warriors
1 transport ( dont know the name)
We deploy, and I win the roll off.
Turn 1 -
DH
Not much for me to do. My Land raider has the termis in it and charges up 12". Nothing in range
My rhino moves, again, nothing in range.
Tau
Moves hit kroot into cover, bring the 2 broad sides forward. Keeps his transport still.
Turn 2 -
DH
I move the LR another 12" down into a river bed. It barely fits ( dooms me later in the game). The broad side with the fusion blaster gets a melta to the face. Since melta is double the broadsides toughness it instant kills him. Take was easy. The kroot are also in range so I open up the the hurricane bolters. 2 die.
The Rhino pushs towards the other broadside. Nothing in range
Tau
The broadside with the cannon blows up my rhino. 1 storm trooper dies. It then uses its smart missiles to blow the storm troopers that got out of the rhino. I have 1 left : /
The kroot race to the front of my land raider
Turn 3-
DH
The LandRaider is in range of the last broadside. A melta takes it out. I open up on the kroot with my hurricane bolters that now roll twice the amount of shoots ( bolters are rapid fire at half the distance) 4 kroot die. The rest are so close to my assult ramp I cant see them.
Tau.
The transport full of fire warriors moves over the other side of my Land Raider. Blocking my other exit point. At this time, I have NO clear exit points on my land raider. (terrain is blocking my other side door, and the kroot are by the assault ramp). His troops disembark and assult my land raider, throwing emp grenades. Nothing happens (yet)
Turn 4
DH
I try to back up the land raider. My opponent tells me that I can not do this, because his unit locked it in assault. We check the the rule book and fail to find anything saying other wise.
I blow up his transport with the melta, 3 fire warriors die.
Tau-
Uses another emp grenade on my land raider, this time wrecking it. Since all of the exit points are blocked the terminators die and the game ends. Just for fun we decide to pretend they can get out.
Turn 5 -
( in summery ) Terminators kill everything
It was a really fun game. Land Raider rushing was very satisfying ( mwahahaha ), I still dont know what to think about that "vehicle locked in assault" rule though.
https://bolterandchainsword.com/topic/183237-deamonhunters-vs-tau-battle-rep/
I'm by no means a rules expert but I', 99% sure you can't lock a vehicle in assault.
Without a WS it can not ever be in assult. Page 63 Successive turns.
The BRB says " If a vehicle that has been assaulted, and has survived, does not move its successive movement phase, enemy models will still be in base contact with it.....etc etc..."
I took that as " if the vehicle has been assaulted it can not move" but after reading it again it never says the vehicle CANT move.
More than that, why would it say "If a vehicle that has been assaulted, and has survived, does not move...." unless the vehicle in question can move? The rules for normal assault don't say "If the enganed squad doesn't decide to just walk away, they will remain locked in combat." It says they're stuck until somebody falls back or uses some other means to escape. (Hit and Run, for example)
With the exceptiopn of vehicles with a WS value, vehicles are never 'locked in combat.' People can walk up and hit them, and then they can just drive away rather than hang around, so long as they're not immobiliuzed, stunned, etc.
Not only could you have moved, you probably could have Tank Shocked his kroot, melta'd the transport (a Devilfish) and bailed out through the side hatch to assauult and wipe the fire warriors.
Realized this after the fact haha. I guess it pays to study the rule book. Its hard to sit down and really read the rules when you are playing an exciting match!
There's quite a bit wrong here. Are you sure you're playing 5th edition?
If a transport's exit points are blocked, they can make an Emergency Disembark. Look it up.
A single broadside unit cannot target a transport, blow it up, then shoot the models inside. All of a unit's firing is resolved at the same time. You shouldn't even be looking at vehicle results or making saves until a unit is done firing everything in the unit. That being said, if a unit blows up a transport, it is free to assault the models that emerge, or another unit may shoot the models that emerge.
A land raider is fundamentally incapable of being locked in assault.
Did your opponent know that you were ignoring the force org completely? His list doesn't look nearly as cheesy as yours is.
As has been established, models that are in base to base with a vehicle that does not move away from them may strike the vehicle in the vehicle owner's assault phase. Of course, during your turn you would probably move to the minimum 1" away and then charge back in for the extra attack.
Rapid fire is 12", not half way (Normally, rapid fire weapons may fire at full distance if stationary with one shot or up to 12" with two shots even if they move.). Don't have my codex here to check on the exact wording of what hurricane bolters count as. Keep in mind this is only Rapid Fire weapons- Don't try and use this with Storm Bolters, for example, as they are assault two, and do not get any extra shots.
Sometimes after a game like this, it's helpful to sit down and read the paragraphs pertaining to the game you just played. It will clear up so many issues. Also, be wary of treating things like they were treated in 4th. Few things are exactly the same, so you actually have to pay attention instead of just assuming things.
Could not find anything on it, can I get a page number please?
From the DH codex, page 32. " Each hurricane bolter counts as three twin linked boltguns"
Yes, we agreed to ignore it since it was only a 500pt. game. I dont think my list was "Cheesy" at all. He could how won easily if he prioritized. He went for my Rhino instead of my LR.
I agree COMPLETELY! This was our first game so we expected to miss some stuff. Thanks for helping me clear it up!
