melabi Posted November 6, 2009 Share Posted November 6, 2009 1. Say the transport has not moved in my turn. Can units with heavy weapons then get off from the transport and shoot the heavy weapon in the same turn? 2. Say the transport has not moved, units then disembarks from the vehicle. what are the options of the disembarked units? The codex says - The unit can move normally/The unit can shoot(count as moving). and assault normally. Can I move-shoot-assault? Or does shooting count as moving so I can 1. move&shoot 2. shoot& assault but not the three put together? Thanks for your answers! Link to comment Share on other sites More sharing options...
rat of vengence Posted November 6, 2009 Share Posted November 6, 2009 1. Say the transport has not moved in my turn. Can units with heavy weapons then get off from the transport and shoot the heavy weapon in the same turn? No. Disembarking is a move, so the squad counts as moving. 2. Say the transport has not moved, units then disembarks from the vehicle. what are the options of the disembarked units? The codex says - The unit can move normally/The unit can shoot(count as moving). and assault normally. Can I move-shoot-assault? Or does shooting count as moving so I can 1. move&shoot 2. shoot& assault but not the three put together? If the transport never moved, as far as I remember, the unit can disembark and then do everything it normally could do. So as long as it fires assault weapons only (pistols, flamer, melta etc) it can then assault. Thanks for your answers!No worries ;) RoV Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted November 6, 2009 Share Posted November 6, 2009 2. Say the transport has not moved, units then disembarks from the vehicle. what are the options of the disembarked units? The codex says - The unit can move normally/The unit can shoot(count as moving). and assault normally. Can I move-shoot-assault? Or does shooting count as moving so I can 1. move&shoot 2. shoot& assault but not the three put together? If the transport never moved, as far as I remember, the unit can disembark and then do everything it normally could do. So as long as it fires assault weapons only (pistols, flamer, melta etc) it can then assault. Almost but it does need to be mentioned that that even if the vehicle did not move disembarking itself counts as movement (though you may still take your regular move in adition to disembarking) so you may not fire heavy weapons, or rapid fire at full range. Link to comment Share on other sites More sharing options...
rat of vengence Posted November 6, 2009 Share Posted November 6, 2009 Almost but it does need to be mentioned that that even if the vehicle did not move disembarking itself counts as movement (though you may still take your regular move in adition to disembarking) so you may not fire heavy weapons, or rapid fire at full range. It was :P No. Disembarking is a move, so the squad counts as moving. RoV Link to comment Share on other sites More sharing options...
