HunterShades Posted November 6, 2009 Share Posted November 6, 2009 hey all - this may be a silly question but if i 'buy' Master of Runes for my rune priest does he get to use 2 powers per turn or just 1 because i looked in the rule book and it said 'may use as many powers per turn as has shooting attacks' so is that 1 because he has a pistol or 2 because he has master? also if i can only use 1 per turn IF he was on a bike would he be able to use 2 due to the bikes TLB or just 1 again just with better Toughness etc - im pretty sure it would just be pistol or bolters but just want to verify can anyone help me become un-confused? Link to comment https://bolterandchainsword.com/topic/184200-rune-priest-confusion/ Share on other sites More sharing options...
DV8 Posted November 6, 2009 Share Posted November 6, 2009 With Master of the Runes, you can use two powers, HOWEVER you are still bound by the normal rules, i.e. you can only make one shooting attack, psychic or otherwise, in a turn, unless other rules specifically over-ride this (Dreadnoughts/Vehicles/Tau Battlesuits/Eldar Farseers/etc.). So you could case one power specifically mentioned as a "psychic shooting attack" (i.e. Living Lightning), as well as a second power with Area of Effect or buffing, but that is not listed as a "psychic shooting attack" (i.e. Stormcaller). DV8 Link to comment https://bolterandchainsword.com/topic/184200-rune-priest-confusion/#findComment-2177558 Share on other sites More sharing options...
HunterShades Posted November 6, 2009 Author Share Posted November 6, 2009 ah thanks for clearing that up - no LL/JOTWW per turn then, ah well ill have to make do with 1 per turn and save the 50points Link to comment https://bolterandchainsword.com/topic/184200-rune-priest-confusion/#findComment-2177561 Share on other sites More sharing options...
Duke Corwin Posted November 6, 2009 Share Posted November 6, 2009 You can also use the MotR to cast a psy ability AND still charge your runic weapon in CC. Link to comment https://bolterandchainsword.com/topic/184200-rune-priest-confusion/#findComment-2177826 Share on other sites More sharing options...
Levitas Posted November 7, 2009 Share Posted November 7, 2009 True. But as the RP has so many shooty powers the master of runes isnt great. Plus with slightly nerfed stats and no storm shield he will get easily outclassed by HQs worth draining dry with force weapon. Wounds demons on a 2+...if he survives their higher Initiative attacks that are likely power hits. keep him cheap, basic. Then play pop n zap in a rhino with a cheap shooty GH squad. No need for master of runes at all. Link to comment https://bolterandchainsword.com/topic/184200-rune-priest-confusion/#findComment-2178007 Share on other sites More sharing options...
lunchb0x Posted November 7, 2009 Share Posted November 7, 2009 The reason to take Master of the Runes. Cast a Shooting Attack. Charge into combat, kill big wound thingy/guy/dude. Or. Cast 1 shooting, and 1 non shooting attack. It has a lot of usage. Link to comment https://bolterandchainsword.com/topic/184200-rune-priest-confusion/#findComment-2178034 Share on other sites More sharing options...
