dreadnought
Hi everyone.
I was thinking about putting chaos dreadnought in my army list but i don't know is it worth it and what is the best configration.
I'am playing AGAINST Dark Angels deathwing with the terminators as a troop choise so please have it on your mind :P
I'd be very greatfull for any advise.
https://bolterandchainsword.com/topic/184316-dreadnought/
Well if you're playing chaos termis with Deathwing rules than your question is better off being asked in the Dark Angles forum. People here will give you good advice from a chaos perspective, or maybe even a DA one, but you're better off going over there.
Oh and, i wouldn't tell them you're on our side : )
https://bolterandchainsword.com/topic/184316-dreadnought/#findComment-2178684
Unless it's immobilized, a dreadnought's fire arc is technically 360 degrees, as per page 72 of the BRB. No way to stay out of that!
you couldn't be more wrong. Nowhere in the rule book does it say the it's fire arc is 360. In fact what it does say is that it's 45.
you can choose a target to pivot towards that's 360, but in the case or Fire Frenzy, your target is chosen for you, therefor not 360. It's a totally different sequence of shooting and is actually the RAW.
https://bolterandchainsword.com/topic/184316-dreadnought/#findComment-2181935
Please take the actual rule discussion to this topic
As for if a Dread is worth, many will say no simply because of the Frenzy rule. It's a unit you do not have control over 33% of the time and they can hurt your men.
I am of the belief that dual CCW dreadnoughts aren't bad per se, there's simply better options in the codex that synergize better with the basic units in the list, so taking the Dreads isn't very efficient.
Dreadnoughts fall under the category - 'fun units'. Take them if you like the model(s)/want to include a wild element in your list. For competitive play, don't take them.
My 2 Kraks
https://bolterandchainsword.com/topic/184316-dreadnought/#findComment-2182072
