WG Vrox Posted November 10, 2009 Share Posted November 10, 2009 Has anyone ran a RB with HF and if so would you have to roll against hitting your own vehicle when the template goes over it? Link to comment https://bolterandchainsword.com/topic/184396-rb-with-tl-heavy-flamer/ Share on other sites More sharing options...
stinkenheim Posted November 10, 2009 Share Posted November 10, 2009 not used it but it wouldnt hit itself in much the same way thata flamer armed marine doesnt burn himself. Link to comment https://bolterandchainsword.com/topic/184396-rb-with-tl-heavy-flamer/#findComment-2179243 Share on other sites More sharing options...
Grey Mage Posted November 10, 2009 Share Posted November 10, 2009 No- technically, if you wanted to go that far youd simply be unable to fire it. There was a very very long discussion in the OR forum about this a while back, the two opinions that arose were thus: Unless properly modelled the Razorback may not fire as it would hit itself. OR A unit firing cannot hit itself with a template weapon- for instance a marine firing a flamer doesnt hit himself, even if the flamer overlaps the base the marine is standing on. Edit: Note, I believe the latter interpretation to be the correct one, as the idea of making a unit in a way that it doesnt function at all is stupid. Its much like saying Blood Angels cant disembark from their rhinos. Link to comment https://bolterandchainsword.com/topic/184396-rb-with-tl-heavy-flamer/#findComment-2179258 Share on other sites More sharing options...
