Garmr Posted November 15, 2009 Share Posted November 15, 2009 Hey guys i've done some bases for my marines with a lot of snow . This is my wolf guard w.i.p before the storm : http://img69.imageshack.us/img69/2312/termy01.jpg And this is him after the storm : http://img690.imageshack.us/img690/4316/snow1.jpg Same thing for the scouts http://img69.imageshack.us/img69/3487/snow02.jpg Later i will put Njal :) What do you think ? Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/ Share on other sites More sharing options...
Wolf Guard Hengist Posted November 15, 2009 Share Posted November 15, 2009 Is it wet on the pictures or is that how it has set? Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2184963 Share on other sites More sharing options...
Heimdal Posted November 15, 2009 Share Posted November 15, 2009 It might be the light but it looks more like ice to me. So here is what I want: * A photo with a white background and better lightning. (Got a macro-funtion on your camera?) * A "how-to" on making your snow-bases. :) Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2184967 Share on other sites More sharing options...
Garmr Posted November 15, 2009 Author Share Posted November 15, 2009 It was still fresh in the photo :) . When it dries it becomes more like snow ! I think it depends also from the mix of water/white glue/Sodium bicarbonate . This is a photo of Njal and his base where the snow is dry . I have to correct some things like the red things on the snow (i used them to help me to place Njal) . http://img188.imageshack.us/img188/3194/njal.jpg To do this effect you must : 1)mix some water and some white glue 2)add to the mix some sodium bicarbonate and mix them ...if you put too much bicarbonate add water and white glue until you reach the mixture that you like 3)put it on the base (i usually paint the base with adeptus battlegrey before this step .) I'll make a tutorial with photos soon ;) . Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2184974 Share on other sites More sharing options...
kapturowski Posted November 15, 2009 Share Posted November 15, 2009 That looks really good! I just bought GW's snow flock and I'm quite dissapointed by it. I will try this immediatly! Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2185037 Share on other sites More sharing options...
Garmr Posted November 15, 2009 Author Share Posted November 15, 2009 I'm glad it's useful ;) ! I've found also this tutorial HERE . ah sometimes the soda could become a little bit yellow , i don't know why this could happens . Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2185042 Share on other sites More sharing options...
Night Runner Posted November 15, 2009 Share Posted November 15, 2009 I like the mix Garmr. Baking soda and white glue is what I usually use. I tried a modeling snow product on my wolves and the result was more like ice than snow. I think I'll try using them together to see how the effect comes out. Personally I think you put a bit too much snow on the first termie (that's just my preference) but it gives a nice effect of charging through heavy snow. Also call me picky but I have a thing for neat base edges (once again, its just me) , but overall I think you did a great job. Well done :D Edit: According to my friend model builders, snow turns yellow due to several reasons. It could be the brand of white glue that turns yellowish instead of transparent when dry. Sometimes the soda absorbs some of the paint pigment (especially if the paint hasn't dried properly), and sometimes it has to do with impurities within baking soda of low quality and purity. Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2185099 Share on other sites More sharing options...
Madsakre Posted November 15, 2009 Share Posted November 15, 2009 Cakemarines Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2185144 Share on other sites More sharing options...
Garmr Posted November 15, 2009 Author Share Posted November 15, 2009 I like the mix Garmr. Baking soda and white glue is what I usually use. I tried a modeling snow product on my wolves and the result was more like ice than snow. I think I'll try using them together to see how the effect comes out. Personally I think you put a bit too much snow on the first termie (that's just my preference) but it gives a nice effect of charging through heavy snow. Also call me picky but I have a thing for neat base edges (once again, its just me) , but overall I think you did a great job. Well done :confused: Edit: According to my friend model builders, snow turns yellow due to several reasons. It could be the brand of white glue that turns yellowish instead of transparent when dry. Sometimes the soda absorbs some of the paint pigment (especially if the paint hasn't dried properly), and sometimes it has to do with impurities within baking soda of low quality and purity. I'm glad you like them Night Runner! I think you said right things about the first terminator and the neat base edges :) , i will fix them soon . Thanks a lot for the comment ;) ! Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2185416 Share on other sites More sharing options...
Growler67 Posted November 15, 2009 Share Posted November 15, 2009 One way to fix the "ice glaze" appearance is after you apply it to your base, "dust" it with more baking soda (sodium bicarbonate). Even waiting a few minutes (depending on how wet you make the mixture) so that the fresh dusting doesn't soak in. This will leave a gritty texture to the surface rather than the "ice glazed" one and give you a more "fresh snow" look. The optional application is to paint your white glue onto your base (if you want less snow or snow only on certain spots) then dust with the baking soda. Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2185449 Share on other sites More sharing options...
nurglespuss Posted November 16, 2009 Share Posted November 16, 2009 You can use Sugar, white paint & gloss varnish for the same effect, and it never goes yellow, ends up looking like this (and I did this a few years ago): http://photos-b.ak.fbcdn.net/photos-ak-sf2p/v217/128/96/633810322/n633810322_3680541_8427.jpg Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2185907 Share on other sites More sharing options...
Night Runner Posted November 16, 2009 Share Posted November 16, 2009 Nice snow effect Nurglespuss, but I have to say I like your painting even better. You broke the brightness of the yellow on that Imperial Fists' dread very realistically without loosing the quality of the yellow. Take a bow you deserve it. :lol: @Garmr - I hope you post more pics when they're ready!! Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2186023 Share on other sites More sharing options...
nurglespuss Posted November 16, 2009 Share Posted November 16, 2009 Cheers mate! not meaning to thread-jack, but thanks alot (I must admit, despite having moved on a bit, its still my favourite army!). Thanks again :lol: Link to comment https://bolterandchainsword.com/topic/184839-snow-for-my-wolves/#findComment-2186050 Share on other sites More sharing options...
