Hjaertrr Posted November 15, 2009 Share Posted November 15, 2009 So i'm putting one together as I speak and was wondering, after a weapon destoryed result its pretty much a cover save on wheels so do people usually eauip it with a storm bolter? Would this help it to maintain efficiency for a while? Is it worth the points cost? Cheers. Link to comment https://bolterandchainsword.com/topic/184888-vindicator/ Share on other sites More sharing options...
Jarl Kjaran Coldheart Posted November 15, 2009 Share Posted November 15, 2009 So i'm putting one together as I speak and was wondering, after a weapon destoryed result its pretty much a cover save on wheels so do people usually eauip it with a storm bolter? Would this help it to maintain efficiency for a while? Is it worth the points cost? Cheers. I dont use them, but my opponents do, so this is what i picked up from them: I have never seen any of them equip it with a storm bolter. That should answer the next two of your questions. I have also never seen it in a position where it didnt get a cover save of some type. WLK Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2185525 Share on other sites More sharing options...
cleanse the impure Posted November 15, 2009 Share Posted November 15, 2009 Ok, personally I wouldn't bother with the storm bolter. Remember, the weapon that is destroyed is chosen by the person who is doing the destroying, so they will remove your demolisher cannon straight away. Thus, if you give the tank a storm bolter, you are making it that bit harder to fully destroy or immobilise but not to remove its main threat potential. Just my two cents. Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2185527 Share on other sites More sharing options...
Hjaertrr Posted November 15, 2009 Author Share Posted November 15, 2009 Ok, thanks for the answer. Just what I needed to know. Cheers. Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2185545 Share on other sites More sharing options...
WG Vrox Posted November 15, 2009 Share Posted November 15, 2009 Now you do understand that a Vindicator does come with a Storm Bolter for the 115 points. Your asking is it worth the 10 points to put another on? If I knew I was going up against a army that auto glances such as Necron, its not a bad thought as it will survive that much longer. For a trouney game, it really comes down to what you plan to do with it and what units you keep around it. Keep in mind that even though a SB is a defensive weapon, you can not fire it and your ordanance weapon. If you could the 10 points would be a no brainer to take for me. Firing 2 SB can be a nice thing in continued operation after your weapon destroyed result is taken. In addition there are times in a game where you will not want to fire your main weapon in fear of hitting your own units, which of course is a nice time to have 2 SB. However the best use of a Vindicator after it's main weapon is destroyed is Ramming with it :D . Make sure you get at least a 10" move and you have a Str 7 hit. Not much but against rear or side armor can cause some damage. When you add in the fact that it keeps moving and can hit a second one if you destory the first, it starts paying off. Vrox Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2185578 Share on other sites More sharing options...
Jarl Kjaran Coldheart Posted November 16, 2009 Share Posted November 16, 2009 In addition there are times in a game where you will not want to fire your main weapon in fear of hitting your own units, which of course is a nice time to have 2 SB. Vrox i dont understand this "fear" thing you speak of??? :lol: i know for team games, its always good to assault a unit that just been shelled upon. if ytou cant take the heat, so off the battlefield! WLK Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2185624 Share on other sites More sharing options...
wiplash Posted November 16, 2009 Share Posted November 16, 2009 bear in mind it is hard to kill a vindicator front armour 13 is too stong for anything under a S7 to hit it but once this has happened use it to ram :D you will usually have a higher armour value than them and if you have moved a fair distance then they can be great Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2185854 Share on other sites More sharing options...
Evilmerlin Posted November 17, 2009 Share Posted November 17, 2009 While we are on the topic of Vindicators, are Siege Shields worth taking? Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2186904 Share on other sites More sharing options...
Wolf Guard Dan Posted November 17, 2009 Share Posted November 17, 2009 bear in mind it is hard to kill a vindicator front armour 13 is too stong for anything under a S7 to hit it but once this has happened use it to ram :Pyou will usually have a higher armour value than them and if you have moved a fair distance then they can be great hahah, i like your way of thinking. spoken like a true wolf lord. that attitude is why we're not a "codex" chapter. Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2186911 Share on other sites More sharing options...
bravelybravesirrobin Posted November 17, 2009 Share Posted November 17, 2009 While we are on the topic of Vindicators, are Siege Shields worth taking? Depends on the tables you play on. Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2187000 Share on other sites More sharing options...
WG Vrox Posted November 17, 2009 Share Posted November 17, 2009 While we are on the topic of Vindicators, are Siege Shields worth taking? Because of the short range, I find myself taking the straightest line between the vindi and what I want to fire at, this usually forces me to roll through woods, ruins or even wrecked vehciles. So at the very least I take a dozer blade. Plus how can you not take it when the model looks so cool. Vrox Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2187020 Share on other sites More sharing options...
Logain the Ranger Posted November 17, 2009 Share Posted November 17, 2009 I have also never seen it in a position where it didnt get a cover save of some type. WLK You've never seen me use them with my BA. Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2187111 Share on other sites More sharing options...
Jarl Kjaran Coldheart Posted November 17, 2009 Share Posted November 17, 2009 I have also never seen it in a position where it didnt get a cover save of some type. WLK You've never seen me use them with my BA. but if your playing BA, i already won. those twilight vamps dont scare me! :) WLK Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2187119 Share on other sites More sharing options...
wiplash Posted November 17, 2009 Share Posted November 17, 2009 While we are on the topic of Vindicators, are Siege Shields worth taking? Because of the short range, I find myself taking the straightest line between the vindi and what I want to fire at, this usually forces me to roll through woods, ruins or even wrecked vehciles. So at the very least I take a dozer blade. Plus how can you not take it when the model looks so cool. Vrox i dont use one i tend to put him on the flanks (so hes more likely to be shot from the front or one side) so they last longer etc. thats simply because the guns range is 24" i keep my whirlwind behind cover miles away from anything if possible :) but the terrain we usually use are buildings so you cant drive throuhg a building so easily. Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2187122 Share on other sites More sharing options...
Logain the Ranger Posted November 17, 2009 Share Posted November 17, 2009 I have also never seen it in a position where it didnt get a cover save of some type. WLK You've never seen me use them with my BA. but if your playing BA, i already won. those twilight vamps dont scare me! :) WLK You won't think they are twilight vamps when my Death Company mix it up in cc :o . Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2187123 Share on other sites More sharing options...
Sven Bloodskull Posted November 17, 2009 Share Posted November 17, 2009 but if your playing BA, i already won. those twilight vamps dont scare me! Hey, Hey, let's not get insulting here! In any case, i love the buggers so much, i use 2 of them. i always equip them with siege shield, since you are going to put them in cover anyhow, no sense in letting them get immoblizied by an unlucky die. I never give them extra storm bolters. And when the demolisher cannon is gone, it is of course time to go to ramming speed ;) Sven Bloodskull Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2187242 Share on other sites More sharing options...
Wolf Lord Fenrir Posted November 17, 2009 Share Posted November 17, 2009 I love using the Vindicator - something has to breach the walls so that the Wolves can pour through and storm the bastion. Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2187356 Share on other sites More sharing options...
Jarl Kjaran Coldheart Posted November 17, 2009 Share Posted November 17, 2009 I have also never seen it in a position where it didnt get a cover save of some type. WLK You've never seen me use them with my BA. but if your playing BA, i already won. those twilight vamps dont scare me! :P WLK You won't think they are twilight vamps when my Death Company mix it up in cc ;) . you say "mix it up" and i read "teach those emo kids what end of the chainsword is sharp" ;) WLK Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2187574 Share on other sites More sharing options...
Warhorse47 Posted November 17, 2009 Share Posted November 17, 2009 Well, I use the siege shield and the extra 'bolter. Link to comment https://bolterandchainsword.com/topic/184888-vindicator/#findComment-2187893 Share on other sites More sharing options...
