Jarl Bloodwolf Posted November 22, 2009 Share Posted November 22, 2009 the topic description pretty much states it. if you only have one drop pod do you have the option to or do you have to use the drop od assault? Link to comment Share on other sites More sharing options...
Isiah Posted November 22, 2009 Share Posted November 22, 2009 To DP assault you can use up to half your pods (rounding up). If you have just one pod you can DP assault with it as you can't really deploy half a pod as you round up to one – same with all other odd-total pods you might have: 1 pod = 1 to DP assault 3 pods = 2 to DP assault 5 pods = 3 to DP assault 7 pods = 4 to DP assault Cheers I Link to comment Share on other sites More sharing options...
chromedog Posted November 27, 2009 Share Posted November 27, 2009 If you have pods (any number) you will be using DP assault. It's what marines do. So, as a result, half (rounding up) WILL come in turn one. If you use one pod, it WILL come in turn one. Link to comment Share on other sites More sharing options...
