a question
Ragnar Blood Giver
ok brothers I have a sky claw pack of 10 with a WGBL and also a rune priest..
now as I see it... if they were to jump from a TH and DS.
could my WGBL take 2 wolves with him?
abide it would limit jump abilities for the SC's but with a rune priest in attendance, my WGBL and his 2 wolves could break away after DSing, so allowing the SC+RP to use their full movement.
so short and simple can he do this my WGBL?
to me yes he can, but....
https://bolterandchainsword.com/topic/185555-a-question/
if your asking if a WGBL with jump p0ack and wolves can deep strike then no, as the wolves do not possess jump packs (the item granting him the deep strike ability) nor do they have it listed as part of their special rules.
the WGBL and wolves can be put inside a drop pod to deepstrike but thats the only way im afraid...
think of it like this, wolves are the very opposite of cats. where a cat will always land on its feet, wolves by their very nature will always land on their faces. no matter how hardy a fenrisian wolf is, being thrown out of a thunderhawk and told to flap isn't going to help it when its face meets the concrete.
https://bolterandchainsword.com/topic/185555-a-question/#findComment-2194188
think of this..
strap them to some BC's with jump packs.... jump out and land, then deploy...
I can't find any where in the book where it says it can not be done..?
reason why I asked.
on pg 85 at the bottom with the * sign.
it says what it says, nothing more and as I said I can't find any other ruling saying it can't happern..
https://bolterandchainsword.com/topic/185555-a-question/#findComment-2194197
im not saying he can't take them if he wears a jump pack, he can, they'd slow him down but he can definately take them.
its just that the wolves don't have the deep strike rule and so wouldn't be able to deep strike into play. as they must remain within 2" of the character it means he can't either
https://bolterandchainsword.com/topic/185555-a-question/#findComment-2194202
if you mean in apocalypse where you are actually using a thunderhawk, then i think (and i may be wrong as its been several years since i last looked into taking one and the was the rules in IA) thats its not a 'deepstrike' as such more disembarking from a vehicle... if i remember then you simply deploy a unit anywhere alog its flight path.
they may have changed the rules in the new datasheets to make it more like a valkyrie in the IG where any unit can deploy and i think they just have to roll a dangerous terrain check if its moved over a certain distance.
i thought you were asking if a WGBL with jump pack and wolves could deep strike, in which case no they can't as i said above.
if you meant can they deploy out of a thunderhawk that your using in you list, then if its treated as disembarking then sure. this would be in much the same way that a WGBL can take his wolves for a ride in a drop pod or land raider
https://bolterandchainsword.com/topic/185555-a-question/#findComment-2194220
jump packs allow you to deepstrike, so any model with a jump pack gains that ability.
you kept mentioning them deepstriking from a thunderhawk, so i wasn't sure if you were talking about actually taking a thunderhawk in a game and having them transported inside it.
i assume you are simply asking if they are allowed to deepstrike (enter play from reserves, scatter all that jazz) and the answer is yes. any model with a jump pack may deepstrike.
the fenrisian wolves taken as wargear by a character cannot deepstrike though because they lack either a jump pack or the deepstrike special rule.
on the other hand, if you are asking if they can deploy from a thunderhawk (the 900pts+ jobby used in apocalypse games) then yes they likely can as i don't think that is deepstriking. withoyut looking at the thunderhawk rules, i think its along the same lines as deploying from anyother vehicle. tis only applies if you are talking abut taking one in a battle, where you pay the points and have the model on the table (or a proxy). im not talking about the fluff reasons as to why jumppacks can deepstrike.
https://bolterandchainsword.com/topic/185555-a-question/#findComment-2194563
Darn it! Now I have coffee on my computer screen!
https://bolterandchainsword.com/topic/185555-a-question/#findComment-2195027
