Storm Caller/Psyker attacks
Primarch_Leman_Russ
2 Quick questions: can Storm Caller obscure vehicles in the same way smoke launchers do (not by 50% rule but by ability rule) except 5+ instead 4+?
can psychic abilities be used when inside rhino by using one of the two fire points for the psher to stick his head out?
Thanks!
https://bolterandchainsword.com/topic/185796-storm-callerpsyker-attacks/
Yeah not a bad idea actually. i run a rune priest with my long fangs fairly often, use living lightning and storm caller to give your preds some cover =)
That's a pretty good idea hadn't thought of that since I run a more rhino rush army. Haven't played My Wolves (or anything for that matter) since the 3rd edition codex came out. Totally skipped 4th edition (horrible for wolves anyway), and was thinking of coming back to playing now that we have a more balanced 5th edition and a new codex.
In 3rd edition I used to run a LRC packed with Wolf Priest and maxed BC's, followed by a GH pack of 9 in rhino with Rune Priest attached. Tactic was to have rune priest cast stormcaller on the LRC from inside the Rhino that I kept hidden behind the LRC. In 3rd edition, this made all pens glancing, so it basically gave me an uber LRC and ensured the unit was delivered where necessary. Granted a 5+ cover save isn't as effective as Pens to glances was in 3rd, but it is offset somewhat by the fact that now stormcaller is area effect so running same set up as before I can have a 5+ cover save for the LRC and the Rhino carrying the Rune Priest and any other rhino's within 6".
The reason I asked about vehicles was because in the rules it says "Friendly Sqauds" not friendly "units," so wasn't sure what Squds meant. Would it just be vehicle "squadrons" or all vehicles, etc...
"That's a pretty good idea hadn't thought of that since I run a more rhino rush army. Haven't played My Wolves (or anything for that matter) since the 3rd edition codex came out. Totally skipped 4th edition (horrible for wolves anyway), and was thinking of coming back to playing now that we have a more balanced 5th edition and a new codex.
In 3rd edition I used to run a LRC packed with Wolf Priest and maxed BC's, "
Both are good things, BCs and a wolf priest make for a great unit for a LRC, Although im still not sure if you can actually grant cover for your tanks. To be honest man, extra armour is almost always more then enough to ensure your LRC will make it to pay-dirt. Its extremely hard to kill av14 in 5th ed. I just run mine with a MM and that gives it an answer to other tanks as well as a extra weapon to get destroyed before the result moves up the chart. I hardly have trouble with my LR being shot down the first turn. If you go second its always an option to hold it in reserve
Why not? What, specifically, would make you think that you would not grant the Cover Save offered by Stormcaller to your vehicles?
V
Does stormcaller grant a cover save in close combat? He uses the power at the beginning of his turn and it surrounds he and all friendly squads within 6 inches. So if he gets into a close combat could he use this 5+ save against power weapons and the like?
I found the rule under the assault section. It says noone can take cover saves in close combat.
no, nothing can be done by characters not on the table. the psyker cannot cast if he is not present. it is the same a a daemon prince with warptime that is deepstriking. he cannot act until he is on table at which point it is no longer the begining of the turn.
Yeah I did some digging for the whole "does it work on vehicles" thing and this is what I am basing my answer of "Yes" on:
1) Same question came up in 3rd edition. Can it give cover save (count pens as glancing) and the answer was YES by official GW FAQ. Makes sense from fluff reason to, it's a freaking storm!
2) In the Spanish, German, and French SW Codex's it says "Unit" NOT "squad." I think a lot of the confusion is caused by it using the word SQUAD (which we think of as squads of men, not vehicles). But the other EU codex's use UNIT which DOES cover everything!
There you have it! If you go to a tourny bring a copy of the official 3rd FAQ and a copy of a German/Spanish/French SW codex and u should be covered!
