Darkmagi Posted November 30, 2009 Share Posted November 30, 2009 I have a question about the psycannons on GKT. If you move isn't your range restricted to the assault range of 18"? I keep seeing recommendations to use GKT as mobile fire-bases kept at 36" under shrouding... wouldn't moving them about cancel out the ability to use the psycannon at full range? any clarification would be appreciated. Link to comment https://bolterandchainsword.com/topic/186055-help-with-psycannons/ Share on other sites More sharing options...
heretic??ME?? Posted November 30, 2009 Share Posted November 30, 2009 Yes unless on terminators. Terminator armor allows heavy weapon use on the move But since you want to react to the enemy fast and get the Storm Bolters into range you got to move. If you don't the enemy heavy weapons are gonna rip up the small numbers in your army. Link to comment https://bolterandchainsword.com/topic/186055-help-with-psycannons/#findComment-2200051 Share on other sites More sharing options...
jeffersonian000 Posted November 30, 2009 Share Posted November 30, 2009 Models in Terminator armour are treated as being stationary when firing heavy weapons regardless of whether or not they have moved. As such, you would use the "Heavy" Psycannon profile rather than the "Assault" profile. Power Armoured Grey Knights with Psycannons that move in the movement phase must use the "Assault" profile. SJ Link to comment https://bolterandchainsword.com/topic/186055-help-with-psycannons/#findComment-2200096 Share on other sites More sharing options...
