Recon squads?
Grim Dog Studios
Collected vissions needs to be takern with a pinch of salt there are a few errors in it. But fluff wise during the heresy space marine armarment was abit more flexable so ye I don't see why not except for the hitting power a marine would use as lasgun if he had no other weopen
https://bolterandchainsword.com/topic/186090-recon-squads/#findComment-2200474
i can see the advantages of lasguns vs bolters for recon marines:
*enough power to kill most things non-space marine
*lighter
*quieter
*ammo easy to scavange so dont need to carry as much
makes sense. unless your doing recon on chaos marines or nids (although i dare say the nids would sense you first).
https://bolterandchainsword.com/topic/186090-recon-squads/#findComment-2200732
  • 1 month later...
This seems an insightful comment with context to 40k, but doesn't really take on board all the different scenarios of a 30k era legion which was quite different.
Consider how a 40k-era chapter operates - they are commonly referred to as the 'surgical blade' of the Imperium's war machine to the sledge hammer of the Imperial Guard. Though they are massively effective, they simply don't have the manpower to be fighting on all fronts and fulfilling all of the aspects of war.
However, consider the role of one of the 20 Legions - they were armies in their own right, sometimes numbering over 100,000 marines (depending on which source you choose to believe). As such, they took on all the vital roles of the battlefield which 10,000 years later would be no doubt fulfilled by Imperial Guard units - garrison, artillery and also recon units amongst other things. Brother Subtle has already pointed out the benefits of a lasgun over a bolter - while a bolter is preferable 99% of the time, there are instances where the characteristics of a lasgun would advantageous.
I'm sure they would be far more effective than a standard lasgun, as Brother-Captain Alecto points out maybe a hot-shot lasgun might be closer to the mark than those wielded by standard IG.
https://bolterandchainsword.com/topic/186090-recon-squads/#findComment-2236369
