Iron Priest
Skirax
Hi, I'm currently thinking of buying a pack of wolves (fangtasy [see what I did?]) and a biker. Using what's left of my two wolf packs, I will make an Iron Priest with the following profile:
Iron Priest - 165 points.
4x Cyberwolf, Space Marine Bike, Wolftooth Necklace, Saga of the Iron Wolf.
I know it seems like a lot of points, and I may drop some cyberwolves, but I like the setup, and I know that the SoIW is not that good when he doesn't have a transport, but I want it purely for fluff purposes, and for honour when he speeds into the enemy zone in the first five minutes, and stays there until the end.
Any suggestions welcome.
https://bolterandchainsword.com/topic/186106-iron-priest/
I'd love to see someone use them. I have never used an Iron Priest since I've been playing and I have never seen anyone else use them down here. Especially now in 5th, since we have such varied elite choices, I'd rather invest in scouts, lone wolves or dreads for small games under 1500pts. Maybe in larger games. Anyways, if you do use them let us know how it went.
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2200609
Pretty sure you can only take 1 cyberwolf? Other than that, I was thinking of a similar set up, as he's very hard hitting. He's not that expensive, and could be used in a similar way to a Lone Wolf, except faster, with more ablative wounds and tougher with the bike bonus. Good combo I say!
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2200643
Q: Wouldn't he be slowed down by the wolves? Can't they only move six inches in the movement phase?
For ten more points you can put him on a Thunder Mount and bump your str up to 9 and get an extra Thunder Hammer attack. (just a thought.)
I'd give him a Wolftooth Necklace also.
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2200649
Wolves are beasts and move at the same speed as cavalry, so get him a thunderwolf, otherwise you're moving six inches - no fleet, no run, no boost, no cav charge.
165 points is a bargain. Keep him towards the back of the advance, and unleash him laterin the game. He is a glass canon, so be careful.
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2201088
Yeah, the bike doesnt add much with the wolves Im afraid. Im making a kitbash footslogger though.... Id suggest going for a TWM and 175 pts. :D
What are you spending those extra 20pts on?
TWM, 4 cyberwolves is 155pts. And pretty good value for the pts IMHO its just that, well, what is he for?
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2201184
You realy don't read the codex that mutch do you? You can't attack a WG to him. Unless of course you mean as a hero, at witch point he would seem a bit fragile. (A lott of points on some very few modells.)
What you can do though is to buy a rhino for you longfangs, in the first turn embark 1 IP, 3 servitors and 3 wolfs in the rhino, and have the move out. At the second (or theerd turn) have them leave and charge whatever you like. :D Servitors are there for wound alocation. I do not know if it is worth it at 160 points though.
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2201501
No no no. Same problem with the Servitors. They make it so you can't get the crazy charge distance. Just go with four wolves that you can slough off as ablative wounds (though at S4 I5, I don't like losing them). Cav moves fast enough that you don't need a dedicated transport. I just keep 'em behind my LRR until something nice and juicy needs hitting, and hitting hard. Honestly, the IP is my favorite unit in this entire codex. For the points, he's just an utter badass of destruction. A bit fragile, but that's what Fen wolves and their cyber buddies are for.
For the Wolftime!
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2201692
Put him on a thunder wolf, have saga of wulfen somewhere and have a pack of regular wolves, let them travel together (netting the irion priest a +4 cover save) have the wolfes charge units and have the priest charge tanks.
He cant join a unit of Wolves- hes not an IC.
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2201736
I run an Iron Priest with saga of the iron wolf, 3 servitors, 4 wolves, inside a Redeemer.
an AV 14 monster that can auto-repair itself untill wrecked, then the unit inside is T5 untill you remove some wolves, in combat you get 7 S8 power weapon attacks on the charge/countercharge... its pretty brutal, the redeemer threatens lots of armies, so you can drive up at full speed (+d3!) then they have to focus on it, if they dont kill it then you just repair and keep on burning. Once it cracks open you just charge the nearest thing and hope to smash some face.
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2201828
Huh. I pretty much wrote off SotIW until now, but that's really not a bad idea. I like my IP Cav unit because he's very cheap for what he does, but if you've got the points and a HS slot to burn, I imagine that would be both a useful and incredibly fun unit to play. I don't have my codex here, but what kind of point value are you looking at for that? I'm thinking at least 500? What point level do you field it at?
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2201857
I have used this unit with great success. I Got a fluffy story line that explains why the IP has his own LRR as well. (when I paint them, they will match unique armor colors within my army).
They greatly benefit from the SoW and though a bit fragile, which for the points it's somewhat expected, they are a very dynamic unit that can take out armor as well as soft targets. You will find that for about 430sh in points, the unit proves itself to be a thorn in your opponent's side the whole game. I highly recommend Extra Armor if you take this unit, which was included in the points posted.
Try to stay away from PF/CF units, but that works well with the Redeemer's target priority as well. As crazy as it sounds that D3 really screws with your opponents movement also as anyone who has run a Redeemer can tell you, that extra inch can be the difference of a few kills and a lot of kills.
Vrox
Edit for points,
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2201894
Just to add my bit...
I've played three games vs Eldar recently (three wins!) and each time I fielded an Iron Priest on a Thunderwolf Mount, with Wolf Tooth Necklace and 4 Cyberwolves at 165pts. Each game I ran them behind a Rhino, or out of LOS at every opportunity.
The first two games the unit was awesome...
Game one it did a 24" charge and smashed a unit of striking scorpions that was about to overrun a Rune Priest and Grey Hunter Squad.
Game two it destroyed a Fire Prism and killed Eldrad.
Game Three it was destroyed in turn two after my enemy cast doom on it and fired a whole load of weapons at it. It left 2 Wolves alive, but with something like Ld 4 or 5 to hit they ran off the board.
Because of this I've downgraded the unit by 2 Cyberwolves - The Iron Priest kills pretty much everything it gets into combat with (especially vehicles!), the wolves are there for wounds - and 4 is a bit overkill for me now - and the 30pts saved is better spent towards the cost of a Whirlwind.
I'd highly recommend it, and I'll post how he performs with only 2 wolves when I next get the time for a game.
ChainsawDR
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2201992
Sadly, when the IP dies, the wolves he brought with him disappear as well. They cannot remain without him. The books says it is assumed that they "drag their fallen master from the field" or some such.
edit: can't spell disappear.
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2202692
Profecy, these cyberwolves are not wargear I think. They come up under the composition part of the unit profile and the Irion Priest is not an IC (although the wargear entry of Fenrisian wolves/cyber wolves do not mention IC character anyway.) The servitours are also part of the unit and they do not disapear when the IP dies. I think the wargear refers to Ragnar, Wolf lord amd Wolf Guard Battle Leader.
I never thought of it as dieciving but when you put it like that it seemed a bit weard (and the IP do not seem so cool anymore.) What do you guys think?
https://bolterandchainsword.com/topic/186106-iron-priest/#findComment-2202745
