whill4 Posted December 3, 2009 Share Posted December 3, 2009 Lets say I equip my GK dread with a twin linked heavy bolter and the standard storm bolter. If I wish to purchase psycannon bolts do I have to puchase psycannon bolts for each weapon or purchase the bolts once for the entire model? Link to comment https://bolterandchainsword.com/topic/186313-gk-dreadnought-and-psycannon-bolts/ Share on other sites More sharing options...
Kabbala Posted December 3, 2009 Share Posted December 3, 2009 Once for the model. Link to comment https://bolterandchainsword.com/topic/186313-gk-dreadnought-and-psycannon-bolts/#findComment-2203289 Share on other sites More sharing options...
whill4 Posted December 3, 2009 Author Share Posted December 3, 2009 Thank you. Link to comment https://bolterandchainsword.com/topic/186313-gk-dreadnought-and-psycannon-bolts/#findComment-2203665 Share on other sites More sharing options...
hendybadger Posted December 3, 2009 Share Posted December 3, 2009 Would using the Psy bolts on Heavy Bolters be better than using the Psycannon from the FW rules? Link to comment https://bolterandchainsword.com/topic/186313-gk-dreadnought-and-psycannon-bolts/#findComment-2203721 Share on other sites More sharing options...
whill4 Posted December 3, 2009 Author Share Posted December 3, 2009 I think the Psycannon would be marginally better. It has a higher strength. But the heavy bolter is twin linked. Link to comment https://bolterandchainsword.com/topic/186313-gk-dreadnought-and-psycannon-bolts/#findComment-2203872 Share on other sites More sharing options...
jeffersonian000 Posted December 4, 2009 Share Posted December 4, 2009 And the Heavy Bolter is tournament legal if IA rules are not. SJ Link to comment https://bolterandchainsword.com/topic/186313-gk-dreadnought-and-psycannon-bolts/#findComment-2204778 Share on other sites More sharing options...
Inquisitor Fox Posted December 4, 2009 Share Posted December 4, 2009 I think the ideal situation here is magnetization, or dry fitting. The Dread model seems fairly simple to swap weapons on the right side by simply owning both, priming and painting both up, then either dry fitting them onto the peg, or utilizing magnets to make the weapons easily swappable depending on what you're planning on doing. Link to comment https://bolterandchainsword.com/topic/186313-gk-dreadnought-and-psycannon-bolts/#findComment-2205129 Share on other sites More sharing options...
