Werewolf3339 Posted December 4, 2009 Share Posted December 4, 2009 I was recently thinking about putting a 3 man lascannon pack of long fangs in a razorback with a twin-linked lascannon on top. I've recently been using 2-3 packs of 5 missile launchers for long range support but I was toying around with the idea of 3 lascannons (1 twin-linked) in one area, able to fire at 3 targets if necessary instead. I think it would be much less vulnerable to fire also, and easily able to scream across the board when needed to contest or move to another position. What do you guys think? Link to comment https://bolterandchainsword.com/topic/186438-long-fangs/ Share on other sites More sharing options...
Grey Mage Posted December 4, 2009 Share Posted December 4, 2009 Why not a 5 man squad in a razorback? Thats what I usually run- PL, 2xML, 2xLC, and a Las/plas razorback. 220pts of death, for three targets a turn. Link to comment https://bolterandchainsword.com/topic/186438-long-fangs/#findComment-2204744 Share on other sites More sharing options...
rodgers37 Posted December 4, 2009 Share Posted December 4, 2009 Why not keep them still? if the move they cannot shoot ^_^ especially if you have LC...... (which have long range, and do not need to get closer...) Link to comment https://bolterandchainsword.com/topic/186438-long-fangs/#findComment-2204776 Share on other sites More sharing options...
Hear da Lamentation Posted December 4, 2009 Share Posted December 4, 2009 Yes, I have read a bit about this before and and mot sure I understand the point. I assume it is just to get them to point "a" as quickly as possible, disembark and keep them there. Otherwise you are losing lots of rounds of none shooting because they are moving. Link to comment https://bolterandchainsword.com/topic/186438-long-fangs/#findComment-2204908 Share on other sites More sharing options...
Hfran Morkai Posted December 4, 2009 Share Posted December 4, 2009 Yes, I have read a bit about this before and and mot sure I understand the point. I assume it is just to get them to point "a" as quickly as possible, disembark and keep them there. Otherwise you are losing lots of rounds of none shooting because they are moving. I believe the Razorback simply acts as another Long Fang, the Fangs don't actually use the transport but 75 points gets you a twin linked lascannon that cannot be harmed on the front or sides by bolter fire, say. I plan on using two LF packs with Razorbacks in 1500 point games, the Razorback is just a cheap predator Link to comment https://bolterandchainsword.com/topic/186438-long-fangs/#findComment-2204917 Share on other sites More sharing options...
Lord Ragnarok Posted December 4, 2009 Share Posted December 4, 2009 What has already been mentioned and that Razorbacks allow the LF's to get into position quickly if the mission is Dawn of War. Link to comment https://bolterandchainsword.com/topic/186438-long-fangs/#findComment-2205021 Share on other sites More sharing options...
Hfran Morkai Posted December 4, 2009 Share Posted December 4, 2009 What has already been mentioned and that Razorbacks allow the LF's to get into position quickly if the mission is Dawn of War. Good point on that. Considering they count as moving anyway you might as well get them a nice comfortable location. Link to comment https://bolterandchainsword.com/topic/186438-long-fangs/#findComment-2205025 Share on other sites More sharing options...
WG Vrox Posted December 4, 2009 Share Posted December 4, 2009 There are a few times when having a RB for your LF is a good idea, Against a demon list or a DP heavy list that will target your LF. I would rather loose one turn of shooting that have them wiped out by a Vanguard unit with AP 2 weapons. Also can be used to limit line of sight to your LF as well as a nice get away vehicle to preserve a kill point. If you want to use a Lone Wolf in your list the RB is a nice option for a taxie and the Lone Wolf's starting position near the fangs gives them a rear guard. Vrox. Link to comment https://bolterandchainsword.com/topic/186438-long-fangs/#findComment-2205037 Share on other sites More sharing options...
