Daemonhuntes HQ weapons?
hendybadger
I am building a large and varied DH force. Mainly Grey Knights but a couple of Inqs with retinues aswell.
My retinues are all sorted but Im abit stuck on the Grand Masters/Brother Captains and the Inq Lords.
With the huge amount of options, how would you arm each to face the different 40K armies they will come across?
https://bolterandchainsword.com/topic/187108-daemonhuntes-hq-weapons/
with the inquisitor, force weapons are good if you have the points. remember, ours don't cause instant death but "kill outright" thus allowing you to kill eternal warriors and monsterous creatures in one shot if I read it right.
with BC's and GM's don't chane their standard CC weapons, they're good enough as it is, if you have to change something give them a psycannon to wreak havoc against your foes.
For Inquisitors, a lot depends on the retinue setup. But, I've used psycannons several times with Inquisitors and a retinue of heavy bolters, mystics, sages.
For Grey Knights, I wouldn't change the weapons except to possibly add a psycannon
I'm not a big fan of equipping DH Inquisitors with force weapons, partly because DH Inquisitors are much better at shooting with their retinue and weapon options and partly because a GKGM's Nemesis Force Weapon is a vastly superior option for killing things in close combat. I generally prefer Inquisitors with Psycannons and GKGMs equipped with their standard wargear, and will often give either of them a psychic hood if you expect to be dealing with psykers.
I've used FW on my Inquisitors before to some good use. Mancatchers and Crusaders for my Hereticus Inq Lord works pretty well - throw in a familiar or three and some medics and it's a dead 'ard squad, especially against solo characters or small groups of nasty melee opponents. Inquisitors with a Force Weapon and Int 5 are pretty handy - 4 attacks on the charge, going first. WS5 means 3+ to hit generally. That's .88 wounds on a MEQ, discounting invulnerable saves. Not a great chance to wound, but all you need is one... And with the medics, he'll last long enough. Espcially with 3 familiars to soak up regular wounds, and Crusaders to take power weapon hits.
The Crusader is an option under the Warrior Henchman available to the Witch Hunters, designed for close combat. He is equipped with a suppression shield (+4 invul) and a power weapon. When he said medic, he meant the Chirurgeon. Without going into too much detail, he allows the Inq to ignore wounds with certain restrictions.
Malleus Inquisitors should always be shooty. My preferred build these days is a cheap deep strike defense bunker: Inquisitor, multi-melta servitor, 2 mystics, in a Chimera or Rhino. If you take an I-lord, add a psychic hood, too. You can always add a psycannon to the Inquisitor and/or a couple more gun servitors.
I have a GM with NFW and Psy and a GM with standard weapons. Any other builds work for those aswell?
Nope, not really. Other than possibly swapping a Storm Bolter for a PsyCannon, there is no reason to select other weapon combinations for Brother Captains or Grand Masters. The Nemesis Force Weapon that they already come with as standard is way too good to give away for something else.
Valerian
Valerian
I didnt realise the NFW was THAT good. I will keep them how they are then
I use either a heavy setup with psycannon, 2 heavy bolters and a plasma cannon (with assorted other guys) or i use a melta retinue with three or more meltaguns in a inducted chimera.
Mel
3 or more meltas? How do you get more?
What about Servitors with Multi-Meltas instead?
Multi-meltas are Heavy, meltaguns are assault. It means that Servitors with multi-meltas have to stand still in order to shoot, so they can't do drive-by attacks and will usually end up being in shooting or even in charge range of the enemy.
This is fine provided you also give the retinue a vehicle to bunker in. Space Marines tac squads do this regularly with their Rhinos. We can do the same, just without the ability to fire more than one weapon out the top hatch. :) (Unless you are able to borrow a ride from someone else NOT from the DH codex.) On the other hand, we can include a limitless psychic hood (on an Inq Lord, at least) and a pair of mystics for deep strike defense. No drop pods with meltas getting too close! ;) I think this is a better deal, overall.
Valerian
Of course they are that good! For your Heroes and Grey Knight Terminators every NFW is a Strength 6 Power Weapon (basically the same as a Codex Space Marine's Relic Blade). I don't remember off-hand how much Relic Blades cost, but its probably around 25 points each (Space Wolves' Frost Blades, which are Strength 5 Power Weapons are 20 points each).
You are getting a weapon that ignores all Armour Saves, attacks at Strength 6 (which Wounds other T4 models, like other Marine Equivilants (MEQs) on a 2+), and still gets to attack at Inititiative. Additionally, if the NFW is in the hands of your Grand Master he can kill any model he wounds with a successful psychic test.
Most other armies would give their left legs for a weapon like the NFW!
V
GM will be keeping a tight grip on his NFW for sure now.
Its sounding like the gunline Inq is the best set-up for anything.
So maybe 3 scribes, 3 mystics, 3 HB servitors and 3 Melat vets. That would then give 2 different ranged loadouts.
For the HB servs I will consider a Psycannon on the Inq. For the Melta vets, maybe a combi-melta and some similar armed Acolytes?
