Newb question - Grey Hunters
Westboarder
I've searched around. Didn't find a clear answer on this. How is it Grey Hunters are able to use Bolters and bolt pistol + chainsword?
They just do? Like chaos marines they're armed with all 3 weapons, the whole 2 weapons max no longer exists. You can give a Dark Angels Company Master a Storm Bolter, Plasma Pistol and a Pair of Lightning Claws for instance.
Shooting phase: They have two ranged weapons, but a regular infantry model can usually only fire one. So they can chose to either fire the boltgun (longer range or double tap) or the bolt pistol (can still assault afterwards).
Close combat phase: They have two single-handed close combat weapons, so get +1 Attack.
There are no rules explaining that a model cannot have more than two weapons (in the old Codices teh armoury introduction used to specify that), and there are no rules saying that the same weapon that was fired with in the shooting phase has to be used in combat.
Excellent. I wanted to model my grey hunters holding a bolter and chainsword. I just wanted to make sure I wasn't off base here.
Modeling grey hunters with bolter and chainsword would be fine, and just be the way they used to look when they had true grit.
*nods* They always count as having their basic equipment, so if you just have a bolter on them, or BP+CCW, or Bolter+BP etc theyll count as having all three, so dont sweat it.
Only if you do something like put a PW or a PG on them does it change, and then as specified in the codex.... so they still have the two unreplaced weapons.
you could also argue that we follow the old legion model rather than the Codex Astartes which would explain the comparable loadouts to Chaos Marines.
I don't think it has anything to do with the ancient Legion organisation, mainly because I can think of no reason why Guilliman would want to change such an equipment loadout. I assume Chaos Marines (and now Space Wolves) got additional weapons to represent their slightly more loose and unordered organisation, where individuals do not carry standardised gear but also usually carry personalised weapons with them.
Because they use this bloody STC technology... called "holsters" I think..
Btw, for sake of WYSIWYG I tend to slap bolt pistol holsters on 2-3 models per GH pack. Works good for me and individualises pack models even further.
Yeah, one tournament I go to you get deducted ponts for not being WYSIWYG. Like not sticking grenades on your (metal) stormtrooper models!
How odd, since GW says you dont have to model grenades.
In my experince most TOs will just say it's their tournament and thats how it is. This particular instance they put it down as something for those who go that bit further. Personally I'm not gonna buy loads of model kits so I have enough grenades/knifes/boltpistols/gasmasks/ration packs for all my dudes. I'm not ubercompetitive so it doesn't annoy me that much.
Indeed. It would be nice if I could model all my Grey Hunters with Bolters and Chainswords with holstered pistols but it's just not going to happen. Likewise sticking both frag and krak grenades on each and every one of them would be ludicrous. Sounds like that TO has some issues.
hmm...at least one of the space wolf armours contain grenades. Also the SW belt with two swords contain grenades. My second ediotion sergant also has grenades on him.
But those rules seem a bit idiotic. I can understand it for necrons maybe who don't have so mutch fluf, but SM? Come on! Just hang in there i supose.
I can understand giving extra painting score or something to such finely modelled units, but dissallowing them seems.... anal.
They're not dissallowed. What happens is you get points for WYSIWYG, and to get those points you need to be detailed enough that all you dudes need grenades and such like. Which is why I never got the points cause I flat out refused to stick grenades (and now bolters/pistols) on everyone. Still managed 3rd place one year though! :) But like I say, I'm not too hardcore so it doesn't bother me that much.
