Silluen Posted December 17, 2009 Author Share Posted December 17, 2009 I don't have my book on my right now, but it says you test for every model that has "entered, left, or moved through dangerous terrain," so it can be triggered in the assault phase as you'll be entering it then. There's no distinction for "only movement phase," as it can happen whenever something moves, be it movement, shooting, or assault phases. I think it's even in the assault phase section when dealing with charging through various types of terrain. But to the OP: You can fly in the movement phase but are forced to walk in the assault phase, hence no dangerous terrain tests then as you're not using your jump pack. Are you guys genius? Or, am I just a fool?Clearly a fool :o, for if you read page 34 in the BRB it says, under Moving Assaulting Models: "Roll for difficult or dangerous terrain if necessary..." Seahawk // What do you mean "you're(means I am) on target"? I just wondered which step of my logic is wrong. :) Anyway first quote is what I have accepted and try to apply at table. But I have a problem to understand why "walking" in movement phase isn't okay, while assault move is safe because of "being forced to walk" as you explained to me. (In second quote, you tought me "if necessary assault move can cause dangerous terrain test" and you might think JI's assault move isn't necessary situation to take dangerous terrain test, I guess.) Please help me out. I just can't get it through my head. :o So, at least assault move is definitely safe, right? I want to land on open terrain and assault into forest or trenches, so walk in movement phase isn't that much important to me. Just curiosity. Link to comment Share on other sites More sharing options...
nighthawks Posted December 18, 2009 Share Posted December 18, 2009 correct. - no dangerous test in the assault move unless the terrain IS dangerous. the issue regarding the safety of walking a jump infantry model can be debated elsewhere. Link to comment Share on other sites More sharing options...
Seahawk Posted December 18, 2009 Share Posted December 18, 2009 You were right is what I was saying. In most normal cases, jumping through open terrain, then assaulting into difficult terrain only causes a difficult terrain test. Some terrain (wrecks, minefields, etc) are difficult and dangerous, so you'd have to roll both when assaulting. The second of my posts you quoted was to show everyone that dangerous tests are not only in the movement phase, a different topic to the one you started. Link to comment Share on other sites More sharing options...
