ntgcleaner Posted December 15, 2009 Share Posted December 15, 2009 So, A friend and I are having a little debate. I think he may be right, though I just want to make sure I shouldn't abandon my argument just yet. We had a game where my IST's disembarked from a Rhino and were standing infront of it. Base to base basically around the left and rear side. He had his commander shoot at the tank and we (at the time) agreed that it would be a normal cover save. Luckily, I saved and the game went on. Later he told me that it is true LOS which means my units could have actually not been in the way. They are scrawny storm troopers, and his thought is that we have to measure from waste to waste, leg to leg to leg to leg, head to head, shoulder to shoulder and so on to figure out if my actual troops are considered 50% in the way of my Rhino. After reading the rules, I still thought this just meant base to base, basically, my storm troopers were a 1"w x 2"h block infront of my Rhino. Here are some images to help us understand. He believes we should measure every gap, like so http://i283.photobucket.com/albums/kk298/ntgcleaner/cover1.jpg I believe it should technically look like this. http://i283.photobucket.com/albums/kk298/ntgcleaner/cover2.jpg Yes, I know, I know, we could just add a -1 modifier to the save, but I just want to be certain as to what the rule is. Link to comment Share on other sites More sharing options...
JamesI Posted December 15, 2009 Share Posted December 15, 2009 Vehicles for cover use true line of sight. How much do the models cover. Ignore the size of the bases. But, don't go so far as measuring. If its close enough that you can't tell by looking, give a 5+ save. Link to comment Share on other sites More sharing options...
ntgcleaner Posted December 15, 2009 Author Share Posted December 15, 2009 that's a good enough explanation. Pretty much what I figured. I just also took into consideration that the unit could be "moving around" on his own base which would account for a harder shot, As they say in the rulebook when they describe such rules. Link to comment Share on other sites More sharing options...
Morticon Posted December 16, 2009 Share Posted December 16, 2009 Yup - as James mentioned TLOS. Old (4th ed) pretty much worked as you described in your second example. But 5th ed is TLOS which means those gaps inbetween legs and models will count for vehicles! Link to comment Share on other sites More sharing options...
