Niiai Posted December 18, 2009 Share Posted December 18, 2009 Gretings fellow brothers! I was just wondering if it is posible to make a plasma and or lascanon dread out of the one that comes in the starting sett? How hard is it? Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/ Share on other sites More sharing options...
Grey Mage Posted December 18, 2009 Share Posted December 18, 2009 Not to hard... you just cut off the MM and then carefully cut the weapons you want to put on to the proper length, then glue them... and be careful that they set straight. Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2219622 Share on other sites More sharing options...
Niiai Posted December 18, 2009 Author Share Posted December 18, 2009 Cool. I would of course need to get the weaponds from somewhere... *ponder ponder* Would devestators work? Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2219626 Share on other sites More sharing options...
Grey Mage Posted December 18, 2009 Share Posted December 18, 2009 Depends- for the Plasmacannon, sure. For the Lascannons I think it would be more difficult, as their is a marine hand holding the LC along the barrel... if you want lascannons the best thin would probly be the razorback kit, and modifying the two LCs from there. Or getting a regular Dreadnaught- TLLC is one of its standard options. Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2219627 Share on other sites More sharing options...
Prosedragon Posted December 18, 2009 Share Posted December 18, 2009 Since armor is more effective en masse buying both the aobr dread and a regular one isn't a bad idea, and they're easy to magnetize. If you're careful about it the aobr dread looks fine converted to have other weapons - my main concern would be the wires coming off the weapon. Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2219877 Share on other sites More sharing options...
Spazmonkey Posted December 18, 2009 Share Posted December 18, 2009 Well here is a AOBR dread I have just started converting, like litterally just started, It took me ten miuntes to do what I have done so far. Cut off the multi melta and attached a plasma cannon from the longfangs. Bear in mind i have just started the conversion and the photo is taken using macro go the join looks x10 biggere than it does in RL. Almost all of my models have been AOBR models that have been converted. http://i682.photobucket.com/albums/vv186/jay_Spazmonkey/swpcfront.jpg http://i682.photobucket.com/albums/vv186/jay_Spazmonkey/swpcside.jpg Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2219886 Share on other sites More sharing options...
commander alexander Posted December 18, 2009 Share Posted December 18, 2009 good job, Im sure it will look good painted, but why two banners? Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2219896 Share on other sites More sharing options...
Spazmonkey Posted December 18, 2009 Share Posted December 18, 2009 good job, Im sure it will look good painted, but why two banners? somthing different, no reason really... i just like the way it looks. none of the dread is glued yet. I litterally just took it off its sprue an hour or so ago. but yeah once cleaned up a bit more, I think it will look good. still want to convert the storm bolter into a heavy flamer and add a greenstuff pelt.... EDIT: and plus this guy that i also just started has one banner. http://i682.photobucket.com/albums/vv186/jay_Spazmonkey/2dreads.jpg Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2219902 Share on other sites More sharing options...
SamaNagol Posted December 19, 2009 Share Posted December 19, 2009 Just buy another arm from Forgeworld for £6.80. It's worth saving up and buying it, because the quality is superb. I am waiting for the FW Dreadnought to be released next year. I have a spare MM arm and an oooooold school Chaos Dread Thunder Hammer waiting for him. So I will have Bjorn with his Claw and another Ven Dread with a T.Hammer. Way better than boring fists! Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2219938 Share on other sites More sharing options...
nurglespuss Posted December 19, 2009 Share Posted December 19, 2009 Good effort, for me though the plasma cannon from the devestators is a bit too small... The ones from a leman russ demolisher look great though... or the old metal chaos dreadnought plasma arm... Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2220007 Share on other sites More sharing options...
Spazmonkey Posted December 19, 2009 Share Posted December 19, 2009 Good effort, for me though the plasma cannon from the devestators is a bit too small... The ones from a leman russ demolisher look great though... or the old metal chaos dreadnought plasma arm... YeaH but its perfect for me, Tight as budget for my hobbies.... so every spare dolloar i can save allows me to put it else where.... Plus I love trying new conversions. Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2220175 Share on other sites More sharing options...
Vaaish Posted December 19, 2009 Share Posted December 19, 2009 I think you need to cut more off the back of the dev plasma cannon you glued on there or trim the arm mount back to the shoulder armor. As it is right now, the front part of the arm is too long. Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2220402 Share on other sites More sharing options...
Spazmonkey Posted December 20, 2009 Share Posted December 20, 2009 I think you need to cut more off the back of the dev plasma cannon you glued on there or trim the arm mount back to the shoulder armor. As it is right now, the front part of the arm is too long. Im happy with it to be honest. I like the extra length, it makes up for the thinner size of it. Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2221423 Share on other sites More sharing options...
SamaNagol Posted December 20, 2009 Share Posted December 20, 2009 That's what she said. Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2221491 Share on other sites More sharing options...
Spazmonkey Posted December 20, 2009 Share Posted December 20, 2009 That's what she said. ROFL..... that is all... Link to comment https://bolterandchainsword.com/topic/187592-making-a-dread/#findComment-2221511 Share on other sites More sharing options...
