KhorneHunter57x Posted December 29, 2009 Share Posted December 29, 2009 Hey all, I have a question about the Baneblade. I have used searchy and I did not find the answer, so here it is: As you all know, a Baneblade has a pair of sponsons. In the options for the Baneblade, there is an option to replace the sponsons with increased side armor for a certain number of points. There is also an option to buy a second set of sponsons. Can you do both options at once? (replacing the built-in sponsons with increased armor and then buying a set of sponsons) Thanks. Link to comment Share on other sites More sharing options...
Grey Mage Posted December 29, 2009 Share Posted December 29, 2009 My group plays yes, but I dont know of any official statement on this one. Link to comment Share on other sites More sharing options...
Frogstaff Posted December 30, 2009 Share Posted December 30, 2009 They're playing it wrong then, because the book seems pretty clear on the issue. You may drop the sponsons and get the increased AV, or instead you may add a second set of sponsons. The 'instead' makes it pretty obviously a one or the other option. Link to comment Share on other sites More sharing options...
KhorneHunter57x Posted December 30, 2009 Author Share Posted December 30, 2009 They're playing it wrong then, because the book seems pretty clear on the issue. Which book? I am referring to Imperial Armor 1, and the IA 1 Update from the Forge World site does not say "instead," but it lists both as individual options. Are you referring to the Apocalypse rulebook? Link to comment Share on other sites More sharing options...
Ian MacKay Posted December 30, 2009 Share Posted December 30, 2009 They're playing it wrong then, because the book seems pretty clear on the issue. Which book? I am referring to Imperial Armor 1, and the IA 1 Update from the Forge World site does not say "instead," but it lists both as individual options. Are you referring to the Apocalypse rulebook? The Apocalypse rulebook makes it very clear that the 2 optional sponsons bring the total to 4 on the Baneblade. The IA Update echoes this with "replace it's two side sponsons with: extra armour plates" and "may take two additional side sponsons..." The use of the word "additional" to me makes it clear that you have to already have two sponsons to add the second two. edit: corrected my quote of the IA update. Link to comment Share on other sites More sharing options...
KhorneHunter57x Posted December 30, 2009 Author Share Posted December 30, 2009 Hmm, I guess you are right. It just seems to me that you should be able to pay the points and take an up-armored Baneblade with 1 set of sponsons. However, I understand that due to the wording of it that you can not do this. I guess this means that if I wanted to do this, I would have to create a special datasheet for it. Thanks for the help all. Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted December 30, 2009 Share Posted December 30, 2009 I think the point is that having those sponsons adds big holes for ammo feads, the guns themselves and all sorts of other vulnerable gubbens, thus preventing an increased armor. Sort of like land raiders not having fireing points. Link to comment Share on other sites More sharing options...
Frogstaff Posted December 30, 2009 Share Posted December 30, 2009 Ahh, I forgot there was an update to IA. I was talking about the Apocalypse printing, since that had been the most up to date rules. The reason that you can't have sponsons plus extra armor is that sponsons have always been a weak point. There's a reason why they haven't been used in in tank design for quite some times. Link to comment Share on other sites More sharing options...
