Size of a Chimera?
cadaver2k
What is the size of a Chimera? Is it bigger, smaller, same as a Rhino body? I will be getting a Armytransport soon and I need to know what size foam I will need to get, I will also get the Chimeras at about the same time but I will not be able to build one before I get the transport so knowing the dimentions rounded up to the next quarter inch would really be fantastic!!! :)
Happy New Year!!! :P
https://bolterandchainsword.com/topic/188663-size-of-a-chimera/
Cant give you the exact size of the acrual models but ive found the specs that in in "real messurements" from lexicanum
Rhino
Worlds of Production: almost every industrialised world in the Imperium
Models: I-VI
Weight:30 tonnes unladen
Length: 6.6m
Height: 3.6m
Hull Width: 4.5m
Ground Clearance: 0.44m
Max. Speed (road): 70kph
Max. Speed (off-road): 55kph
Armour: 30-60mm
Crew: 1 (driver)
Chimera
Forge World of Origin: Gryphonne IV Known Patterns: III-IX Traverse: 360 degrees
Crew: Commander, Gunner, Driver
Powerplant: Vulcanor 16 twin coupled multi-burn
Weight: 38 tonnes
Length: 6.90m Armour
Width: 5.70m
Height: 3.72m Superstructure: 150mm
Ground Clearance: 0.45m Hull: 100mm
Max Speed - on road 70kph Gun Mantlet N/A
Max Speed - off road: 55kph Vehicle Designation: 0427-941-3004-CH080
Tranport Capacity: 12 Firing Ports: 6 (3 left, 3 right)
Access Points: 1 Rear
It´s wider, about a "track" wider (~1,5 cm), about the same height, though if u add the searchlight and don´t cut the "radio mast" then it´s higher.
But as I don´t have a rhino here atm, only a Chimera, it´s best if u check pictures and maybe go to GW´s website, they might have the currect specs.
The most important thing I've found is that it's wider than the Rhino, so you have to put it in at an angle but it'll still fit in a "Rhino sized" foam slot. It helps that you can remove the turret!
If you can, you might want to hold off a bit as the new Guard Chimera chassis vehicles have a new thinner design (the Hellhound and the Bassie in the Battle Missions picture) so you'd be able to transport them easily. No idea when the new Chimera kit will arrive though (is March too much to hope?) so it depends on how long you can wait!
