Thunderpup Posted January 3, 2010 Share Posted January 3, 2010 So, I want to try a Dreadnought with dual TL ACs. As you know the kits don't come with them. I tried Forgeworld, but the left and right guns don't match. And for some reason items wont go into the shopping cart for me. (Shrugs) So. Any idea where i can find some TL ACs for my Dreadnought? Or maybe a way of making my own? Thanks, Pup. Link to comment https://bolterandchainsword.com/topic/188760-twin-linked-autocannons-for-dreadnoughts/ Share on other sites More sharing options...
commander alexander Posted January 3, 2010 Share Posted January 3, 2010 you could probably make them from the dreadnought arms and the autocannons from Imperial Guard heavy weapons teams, as they iclude the ammo drums that you see on the side of the forgeworld ones. Link to comment https://bolterandchainsword.com/topic/188760-twin-linked-autocannons-for-dreadnoughts/#findComment-2233636 Share on other sites More sharing options...
infyrana Posted January 3, 2010 Share Posted January 3, 2010 Just for reference, the standard SM Auto Cannons on FW do match (left and right). The third option from FW is the Right arm auto Cannon for the Mk IV model, that's the one with the exposed ammo shells in the drum magazines (that's what it looks like to me anyway). I have one of each for both a Ven MkIV dread with auto cannon and power fist, plus a dual auto cannon option. As for making your own, you could always take a left and right arm and play with some tubing and barrels for ammo drums. My first attempt was to customise a las cannon, filing the ends flat and adding drum mags for that ultimate first impression giveaway. Link to comment https://bolterandchainsword.com/topic/188760-twin-linked-autocannons-for-dreadnoughts/#findComment-2233638 Share on other sites More sharing options...
commander alexander Posted January 3, 2010 Share Posted January 3, 2010 I tried that lascannon thing, it didnt look too great :) Link to comment https://bolterandchainsword.com/topic/188760-twin-linked-autocannons-for-dreadnoughts/#findComment-2233640 Share on other sites More sharing options...
Thunderpup Posted January 3, 2010 Author Share Posted January 3, 2010 Thanks guys. :) Cheers Link to comment https://bolterandchainsword.com/topic/188760-twin-linked-autocannons-for-dreadnoughts/#findComment-2233654 Share on other sites More sharing options...
WG Vrox Posted January 3, 2010 Share Posted January 3, 2010 GW puts a nice Planet Strike Aegis Defence Line model out that has a double left side right side AC on top of it. It takes some conversion work but nothing crazy. fairly cheap too. Vrox Link to comment https://bolterandchainsword.com/topic/188760-twin-linked-autocannons-for-dreadnoughts/#findComment-2233655 Share on other sites More sharing options...
lunchb0x Posted January 4, 2010 Share Posted January 4, 2010 the right and left do match, it just depends on what "age" you want to get...exposed rounds, non exposed rounds. Link to comment https://bolterandchainsword.com/topic/188760-twin-linked-autocannons-for-dreadnoughts/#findComment-2233817 Share on other sites More sharing options...
Grey Mage Posted January 4, 2010 Share Posted January 4, 2010 GW puts a nice Planet Strike Aegis Defence Line model out that has a double left side right side AC on top of it. It takes some conversion work but nothing crazy. fairly cheap too. Vrox This is a good idea, take the LC and ML arms, chop off the LCs and file down the missiles, attach the autocannons to the front and the ammo barrels to the sides, should work like a charm. Link to comment https://bolterandchainsword.com/topic/188760-twin-linked-autocannons-for-dreadnoughts/#findComment-2234017 Share on other sites More sharing options...
Max_Dammit Posted January 4, 2010 Share Posted January 4, 2010 As far as i can see on the FW site do the mark V auto cannons match left and right Link to comment https://bolterandchainsword.com/topic/188760-twin-linked-autocannons-for-dreadnoughts/#findComment-2234126 Share on other sites More sharing options...
Yeti Posted January 4, 2010 Share Posted January 4, 2010 If you can get an extra TL-Lascannon arm, it works great for the right arm. Just chop off the barrels and replace with IG weapon team autocannons. I'm still wrestling with the left arm ... I plan on converting a ML arm the same way or building one from the ground up. I'll also confirm that the FW arms match, I've seen them on a friends dread and they look good. Link to comment https://bolterandchainsword.com/topic/188760-twin-linked-autocannons-for-dreadnoughts/#findComment-2234258 Share on other sites More sharing options...
