Nob bikers
CrazyCanuk
Ahoy hoy!
I am currently putting pen to paper and really trying to hammer out a space wolf list to aim for. And I seem to have all my bases covered except Nob Bikers. How do Space Wolves deal with them?
I am really going on the deep end and assuming they are upgraded to the gills. They will reach you, and they will drop have your army. Is it something as simple as driving up about 3 Grey Hunter squads and unloading Bolters goodness? I just can't figure uot a reliable way to deal with FnP.
Maybe there is a simple answer and I am just blind, but what is the general consensus on this issue!
https://bolterandchainsword.com/topic/188865-nob-bikers/
Well, the last time I played against Nob Bikers was before our new 'dex. Back then, I had no trouble with them, to the point where the ork player stopped using them entirely.
Amassed bolter fire works wonders, as does plasma. Space Wolves are one of the better-equipped armies when it comes to taking down Nob Bikers. Now that I think about it, I wonder what a few Wolf Claw Wolf Guard would do to them...
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2234789
one word, VINDICATOR (it had to be in captials because its not a subtle vehicle).
yeah its relatively short range, but it will instant kill them, ignore thier FNP, force pinning check (great for shooting the survivors)... awesomesauce.
otherwise a few missile launcher shots a turn should deal with it nicely (double T so no FNP, ap 3 so no armour save) or a fudge lot of heavy bolters as a last resort...
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2234869
Simple Solution : Long Fangs with missile launchers. Accurate, instakilling, no save, no FnP. They muff their inv. save and they're toast.
I've found that bolter fire isn't that useful. If you're in rapid fire range, you're too close and needing a 5+ to wound ... make you sympathise with IG. :)) Add in would allocation tricks, you'll be lucky to kill one. Massed plasma works, but is expensive and it's dangerous, once again, it works best when you're too close for comfort.
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2234894
Ahoy hoy!
Id say 3 GH squads unloading Plasmaguns and PPs would do a sight better- no feel no pain at any rate.
Just remember, you have about 600-750pts to deal with them, as thats what the ork player pays for said units of bikers+warboss.
A pair of Lone Wolves is also a good idea, when equiped with thunderhammers... but that requires some finesse to get them in CC with the Nobz and not a boyz unit.
Another excellant option is some of your own "nobz" in the form of WG- wether on foot, LR, or biking a few powerfists to dish out the damage and insta-kill some nobz and a couple stormshields to take it and youll soon find you outclass those hells-angels wannabes.
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2234897
cause as much difficult terrain as possible , you can not turbo boost through difficult and if you move through it at normal speeds you cause your opponent to take dangereous terrain rolls. not only are you limiting the field and movement but you can use the unit causing the difficult terrain as a distraction but making the nob bikers either deviate towards them , or ignore them and take wounds from the rolled ones.
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2234994
I recently faced such lists and an eldar player who thought that they were the be all and end all. it's funny when you think about them boasting of it and the getting trashed. but onto the topic
on topic:
S8 weapons - preferably AP1-2 and weapons that ignore the FNP, but missile launchers are fine just don't rely on them.
JOTWW anyone?
Murderous hurricane can be a pain for them.
Also, they will get pummeld against a frost blade army :).
Make sure you always have something between you and them however, to stop the from charging your units that can deal with nobz bikers ( small squads, i say small so that you get to blast them to death next turn ) or transports like rhinos.
Hope that helps!
thanks
antique_nova
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2235260
yep longfangs with frag missiles (I know th strength is low, but man those massed templates are winning me games against tough units lately!) and twin autocannon dreads, also twinn assault cannon razor back. Last game I faced 'em, (unit of 8) I wiped em out in 2 turns (good dice rolling on mhy part, unlucky coversaves etc. on my oppnents).
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2235294
if you must engage them in combat use thunderhamers/pwerfists. frostblades whilst nasty still need to wound twice to remove an ork, whereas the thunderhammer/powerfist only needs to cause one wound. Instant death is your friend.
@ antique-nova if the weapons are str 8 they dont need the high ap. FNP doesn't work against power weapons, ap 1 or 2 or wounds that would cause ID so normal missile launchers will ignore FNP because they would cause ID.
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2235296
S 8 Weapons are not that useful, especially krak missiles. They will probably have a warboss in the unit, which has native T 5. If he takes the missile hit, he is not instantkilled, and gets FNP. Massed missiles might work, as he cannot allocate more than one to the warboss, through.
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2235347
problem with the vindicator is, its just too obvious a tank, theres no subltey (not saying there should be any). If I were the ork player I would turbo boost well away from it, and stay fanned out to reduce such template tempting.
Personally, if I were offered long fangs or vindicator, I'd take the longfangs.
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2235386
I could be misremembering (I don't have my Ork 'dex available at the moment), but I thought the Warboss had T4. You may be thinking of his S?
That's fine, too. Ork bikers don't do squat at long range, and they only charge 18".
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2235402
but the vindicator is also useful against mega-armoured nobs, battlewagons, dreads, kans etc... basically it is useful against targets that missile launcher armed LFs struggle with due to high armour or good save.
its also a nice detterant as it forces the opponent to either brave its fire or avoid it, couple it with some melta armed land speeders or such like and it becomes extremely effective at funneling enemy units into positionsthat you want them in.
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2235404
I play an orky player regularly and I thought that Ork Bikers had a 3+ cover save because of the dust they kick up or something like that.
Anywho, I have not faced a big unit of Nob Bikers before, largely because of how many boyz he can field for the price does more to ensure he will hit close combat than a single unit of bikers. For his normal bikers I have used Murderous Hurricane (for the dangerous terrain tests) Living Lightning (for the 2+ and 3+ to wound) JotWW (Remove Model from Play!) Vindicators (Pie plate of Instant Death!) Krak Missiles (No armor save or FnP!) Heavy Flamers (Ignores their cover save!) Plasmaguns (No armor save and wounding on 2+ or 3+) Meltaguns (short ranged but Instant Death and if by some miracle you aren't charged you can take the fight to em!) Long Fangs with PlasmaCannons, Missile Launchers, and Heavy Bolters (The worst roll to wound you will have is a 4+ but those guns fire 3 times, spam it up!) And that doesn't even cover the Close Combat options. Granted these are not the FnP Nobs but most of these options will still put a hurt on them.
Point is, we have a hella lot of options on dealing with them. You really don't have to tailor the list to specifically deal with that unit, most of the stuff you would normally use against orks will work against the bikers. Still, luck plays a giant part in whether or not those Bikers meet their timely end or hit your Grey Hunters and munch 'em.
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2235435
And that's why i take 2 of them.
Sven Bloodskull
https://bolterandchainsword.com/topic/188865-nob-bikers/#findComment-2235593
