Best anti-Nightbringer?
Okidus
I am fighting crons tonight, and he always brings one of the big baddies.
What is your opinion on the best anti tech?
I am thinking Stern for the cheap 140, and FW, but you still need that 6 to wound him... thoughts?
I'd say, stay the hell out of combat with him. S9, 5 attacks and ignoring all possibles means that he will kill anything he happens to bump into in combat. I say, psycannons can help, still wounding on 6's, but ignoring his Inv. In combat, I think the best bet would be hammerhand, then you strike first and wound on 4+. Still hitting on 4+ too, but at least you may cause him to take wounds by number of wounds suffered.
Careful though, as when it dies it explodes, potentially killing anything around it.
If you have landraiders, they can pump out a number of high strength shots which can help. Purgation squads with four psycannons are expensive, but can potentially kill it in a couple of turns. It is slow though, so it is potentially possible to lure it away from the rest of the necron army (maybe with the terminators), then strike at the warriors while the C'tan is distracted and drawn away.
It depends on if you're running a DH or WH list. Personally as I'm a WH player I'd point Exorcists and Land Raiders at it and shoot it until it falls down... but there's a better possibility.
Ignore it.
You're fighting Necrons, which means you should ignore the big scary thing (Monoliths, Nightbringer, etc) and go for a phase out. By concentrating your attention and firepower on the basic troops you can eliminate the nasties without ever firing a shot at them. This also helps as these tend to be the scoring units as well, which helps you complete mission objectives.
Just a thought ;)
I suggest reading what INP posted again and again until it sinks in. ;) The advice is spot on. Anything not a "Necron" should be ingored. If you have to, feed the big guy a sacrificial unit or two while you phase out the army. You should, in fact, be thanking your opponent for wasting points on such a monstrosity. He's just made your job that much easier.
It's been said by very smart people. Anything not named "Necron" do not matter. Stay away from anything without the name "Necron" and destroy the ACTUAL Necrons! Phase out is a huge pain for Necron players and he (like said before) just made it a LOT easier for you.
As a 'cron player myself, I'll just echo what INP, #6, and others have already said. Any Necron player who takes a Nightbringer is just asking to be phased out.
Here's the order of what to kill:
-small squads of "necrons," such as Wraiths, Destroyers, and Heavy Destroyers
-easy to kill "necrons," such as Warriors and Flayed Ones outside of Res-Orb range
-anything else "necron," such as Immortals, Lords, and anything in Res-Orb range
-there is no 4th category, because you phased him out at least 2 turns ago :)
