minionboy Posted January 10, 2010 Share Posted January 10, 2010 So I'm in the process of building a Space Wolf force and planned on having a squad of 4-5 wolfguard in TDA cruising around causing problems. The only problem is that I'm not 100% sure how to equip them. I have a general concept for the squad, just working though how many power fists to roll in. Currently they're assembled with: SB + WC SB + WC+ CML 2 WC PW + SS CF + SB Lascannon's get dropped on the poor sap with the shield, the rest mostly do their thing as needed. I was rolling up against some of the new big bugs and I was a bit disappointed with their performance having only 1 high strength weapon. Do you guys think it would be worth while upgrading one of the single WC models to have a PF/CF? Thanks! Link to comment https://bolterandchainsword.com/topic/189322-tda-wolfguard-question/ Share on other sites More sharing options...
Grey Mage Posted January 10, 2010 Share Posted January 10, 2010 Probly, the question is do you intend for any of these to be pack leaders, or are they all part of a squad in your mind? Link to comment https://bolterandchainsword.com/topic/189322-tda-wolfguard-question/#findComment-2241403 Share on other sites More sharing options...
minionboy Posted January 10, 2010 Author Share Posted January 10, 2010 These are the wolfguard that will be acting as a squad. Also, I should add that I'm also considering switching one or two of the stormbolters to combi-bolters if I can decide between plasma and melta. Link to comment https://bolterandchainsword.com/topic/189322-tda-wolfguard-question/#findComment-2241414 Share on other sites More sharing options...
Grey Mage Posted January 10, 2010 Share Posted January 10, 2010 I would say that 9/10 times if Im only taking one or two combiweapons Id rather have the meltaguns- so I can pop a heavy transport like a battlewagon to get at the gribblies inside. And Id make the WC with CML a PF with CML personally, or move the CML to the 2x WC model... or both. Link to comment https://bolterandchainsword.com/topic/189322-tda-wolfguard-question/#findComment-2241518 Share on other sites More sharing options...
minionboy Posted January 10, 2010 Author Share Posted January 10, 2010 I would say that 9/10 times if Im only taking one or two combiweapons Id rather have the meltaguns- so I can pop a heavy transport like a battlewagon to get at the gribblies inside. And Id make the WC with CML a PF with CML personally, or move the CML to the 2x WC model... or both. Actually, I was just in the process of removing the WC arm on the CML and cleaning a PF as I read your post. Great minds think alike! Still debating on the combi weapons however. Link to comment https://bolterandchainsword.com/topic/189322-tda-wolfguard-question/#findComment-2241548 Share on other sites More sharing options...
Grey Mage Posted January 10, 2010 Share Posted January 10, 2010 Well Plasma will help killing enemy elites, and is good vs light tanks. Melta is just a tank killer- and frankly WG are good at chewing through enemy elites really. But with relentless on them Plasma wont keep you from assaulting, and as theyre equal points its really down to personal preference. Link to comment https://bolterandchainsword.com/topic/189322-tda-wolfguard-question/#findComment-2241552 Share on other sites More sharing options...
