commander alexander Posted January 10, 2010 Share Posted January 10, 2010 Okay to make this really clear, THIS HAS NOTHING TO DO WITH SCOUTS, DO NOT EVEN MENTION THEM. So I have a question to do with saga of the hunter. If the model with said saga is being held in reserves to be deployed with a unit, will he and that unit still be able to outflank, as he is attached to that unit? Link to comment https://bolterandchainsword.com/topic/189336-saga-of-the-hunter/ Share on other sites More sharing options...
Grey Mage Posted January 10, 2010 Share Posted January 10, 2010 *blinks* Yes. Assuming that unit could anyways. The problem being that only one unit in our codex can outflank- scouts. Wich leads us right back into that bit again. Basicly I believe that the FAQ shows us what should be common sense- that hes using the end rule "outflank" and so doesnt force the unit to lose their rules as they are also using "outflank". Link to comment https://bolterandchainsword.com/topic/189336-saga-of-the-hunter/#findComment-2241526 Share on other sites More sharing options...
commander alexander Posted January 10, 2010 Author Share Posted January 10, 2010 I did go through the official FAQ and did not see a question pertaining to Saga of the Hunter in this situation. So youre saying that since outflank isn't a rule, its just a form of deployment from reserves, that the unit he is with also benefits from the saga. Link to comment https://bolterandchainsword.com/topic/189336-saga-of-the-hunter/#findComment-2241534 Share on other sites More sharing options...
Grey Mage Posted January 10, 2010 Share Posted January 10, 2010 No, they dont- but they dont lose outflank *as some suggested* when he joins them, bungling the whole thing. He doesnt confer his deployment abilities to the squad... theres no provision for that anywhere in the rules that I can find. What makes you think its a possibility? Link to comment https://bolterandchainsword.com/topic/189336-saga-of-the-hunter/#findComment-2241536 Share on other sites More sharing options...
stinkenheim Posted January 10, 2010 Share Posted January 10, 2010 you cant have him join a unit of bloodclaws and then outflank... no, its just wrong and nasty.... wolf scouts are the only unit able to outflank in our army, if a character with SOTH joined them they would still be able to outflank/BEL units without infiltrate/scout (the rule which enables them to outflank) dont benefit from the characters outflank rule just because he is there Link to comment https://bolterandchainsword.com/topic/189336-saga-of-the-hunter/#findComment-2241651 Share on other sites More sharing options...
