Solution for the slide
WG Vrox
After being frustrated with those plastic GW tables that make your models slide or many other surfaces that allow the models to slip I decided to find a solution.
You know what I mean that one metal model you have falls over due to a table bump and slides grinding it's paint off on the way down the slope it was peculiarly posed on. Doesn't even have to be a metal model to slide but all the same.
What I ended up doing is dipping the base in "PLASTI DIP" this gave the bottom of the base a rubber coating that was enough to ensure the above won't happen very easily again.
PLASTI DIP is a spray can that I sprayed into a wide mouth plastic bottle cap, once I made a bit of a pool into it I started dipping my model bases into it, just a dab will do it and it dries fast if you make a thin layer. Setting the model on its side seems to do fine for drying.
Thought I would share with anyone that has had the same issues and wanted a solution.
Vrox
https://bolterandchainsword.com/topic/189594-solution-for-the-slide/
Vrox
That's a great idea. I am currently using resin bases and they slide even worse than slotted bases with metal figures. Looks like I need to get a can on my next trip to HD.
As long as we are throwing out niffty little tricks, guy that ownes a LGS put earth mags on the bottom of his bases and uses a steel cookie bake sheet as his tray to carry his army around.
They just snap on and he can turn it upside down without anything moving at all. Thought that as kinda slick.
Vrox.
We use pennies in England.
But the other day I went into a bike shop and the guy gave me all of the punctured inner tubes that they usually throw away from repairs. I took them home and cut them up and glued them onto the bottom of my resin bases. I will probably do the same thing with my slotta bases after filling them up with polyfila.
it is funny, the table mentioned was never put together or used at the closest place to me currently, and i haven't noticed it at my REAL gaming store, so i think that they are over all not great tables, i like the idea of modular but hate the sloped length.... if you get that....
