Lukas and Super Heavies
melabi
Ok then how about Lukas Last laugh? Would THAT remove big things from the game?
According to the FAQ the answer is yes. It'll get rid of friendly models, vehicles (including any tranported models) and even Warlord-Class Titans, basically it'll remove any model in base to base. However models with an ability to return to play (such as Necrons, St Celestine etc.) can still come back.
Actually, NO. Lukas' the Last Laugh rules clearly state that they only "Affect" super heavies. It Affects, not removes.
You then go to the book which contains all the rules for super heavies, i.e. the apocalypse book, and you will see that it quite clearly states that super heavies can never be removed from play by an ability/ power. Instead, they suffer D3 structure points worth of damage.
This came up recently in the gaming group, and a quick read through the apocalypse rulebook cleared it all up.
It clearly states that all models in base contact are removed from play. However it reads that both players take initiative tests. This means it is in cc only, which means that Lukas would either have to be tank shocked by the super heavy or in cc with it (assuming it has an initiative).
The Codex supersedes!
No, actually, normal units would be removed from play. Since the apocalypse rulebook states that anything that forces a super heavy unit to be removed from play, instead causes the super heavy to take d3 structure points of damage. codex supercedes normal rulebook, but this is apocalypse.
Please read the Space Wolf FAQ!
Page 3:
Q. Does Lukas the Trickster’s The Last Laugh ability affect friendly models? How about vehicles? Or Warlord-class Titans, for that matter?
A. Yes in all three cases – it affects any unit in base contact. Stasis fields are very all-or-nothing affairs!
kthxbaibai
What about vs a bastion in planetstrike?
Yes. I can see it now.
A brick falls on Lukas head from high above, cramps his hairstyle and crushing his skull, killing him instantly. And BAM! The stasis bomb goes off and the bastion gets the "most well-kept building"-award for years to come.
Page 3:
kthxbaibai
Err, that doesn't refute his point.
The FAQ only states that the Last Laugh power does affect any unit in base contact. In the case of super heavy units, when they're affected by something that would force a unit to be removed from play, they instead take D3 structure points of damage. The FAQ just confirms that the power does, in fact, affect any unit in base contact with Lukas; it doesn't override the rules for super heavy vehicles.
Now, that last bit about stasis fields being "very all-or-nothing" affairs might suggest that they meant otherwise, but I think that Tograth's point here is pretty strong.
Personnaly I am in the D£ camp myself. I would love it to just take a heavy unit of the board but that would be to much, Imagin in apoc a whole army of Lucus Running around blowing Titans up. He would certainly make up his points value then
you can only have one lukas because he is "unique"
Personnaly I am in the D3 camp myself. I would love it to just take a heavy unit of the board but that would be to much, Imagin in apoc a whole army of Lucus Running around blowing Titans up. He would certainly make up his points value then
In apoc I thought you could field 4 abadabadoodans as long as you called them something different?
