Sister Rosette Soulknyt Posted January 20, 2010 Share Posted January 20, 2010 Hiya does anyone have the new Imperial Armour Apocalypse 2 book yet and could you tell me the new Excorsist formation, as the Forgeworld site is a little blury to read. Would any kind soul share ?? Link to comment https://bolterandchainsword.com/topic/190225-imperial-armour-apocalypse-2/ Share on other sites More sharing options...
andrewm9 Posted January 20, 2010 Share Posted January 20, 2010 The first is the Chorus of Faith. It is composed of 3 to 5 Exorcists. You are considered to have Holy Icons and Laud Hailers on all of them. The cost is assumed in the formation cost. The big ability of the Chorus is to choose a single target once per game and lob double the normal Exorcist missiles from each tank in LOS and range. Thats up to 10d6 Exorcist missiles. the drawback is that any tank that participated in the barrage cannot fire in in the next turn similar to Dire Avengers using Bladestorm. The second is the convocation of Wrath. It consists of a Canoness and her retinue in an Immolator as the command unit, 2 more Immolators, and 2 to 4 battlesister squads in Repressors or Rhinos. The squads must contain a heavy flamer. There are two major benefits to the formation. All flamers (heavy, normal, twin linked etc.) gain +1 Str as long as the command unit is still alive as well as re-rolling all dangerous terrain tests no matter how fast you moved. I'm working from memory so some of this may be a bit off. All in all the book itself is worth a read and possibly picking up. As IA books go its cheap. Link to comment https://bolterandchainsword.com/topic/190225-imperial-armour-apocalypse-2/#findComment-2254623 Share on other sites More sharing options...
W.A.Rorie Posted January 23, 2010 Share Posted January 23, 2010 thanks for the input I was thinking on buying it but you made so I will buy it Link to comment https://bolterandchainsword.com/topic/190225-imperial-armour-apocalypse-2/#findComment-2258841 Share on other sites More sharing options...
