Vorrt Posted January 22, 2010 Share Posted January 22, 2010 So if this has been asked elsewhere, could someone please point me out where it has been answered. Do the sponsons on tanks count as 1 weapon system and have to fire at the same target or are they separate and can split fire on something like a land raider using machine spirit? Link to comment Share on other sites More sharing options...
Jeffy.Gee Posted January 22, 2010 Share Posted January 22, 2010 Off the top of my head I'd say the same target. Unless your codex gives a specific example, I'm pretty sure it has to be the same. JG Link to comment Share on other sites More sharing options...
Interrogator-Chaplain Ezra Posted January 22, 2010 Share Posted January 22, 2010 Each sponson is a separate weapon. Link to comment Share on other sites More sharing options...
Cptn. Palladorus Posted January 22, 2010 Share Posted January 22, 2010 Each sponson is a separate weapon for purposes of determining how many weapons can fire, and in the case of the Land Raider, thanks to the PotMS rule one more weapon can be fired each turn than would normally be allowed for its movement speed and one weapon can be fired at a different target than the rest. Ordinarily though, all weapons on a single vehicle must be fired at the same target, unless it's a super-heavy vehicle. Link to comment Share on other sites More sharing options...
Grey Mage Posted January 22, 2010 Share Posted January 22, 2010 In normal 40k all weapons in a unit must be fired at the same unit- thus, all weapons on a particular tank should be fired at the same target. Note, for weapon destroyed each weapon is seperate, and each weapon has its own fire arc and LOS. Link to comment Share on other sites More sharing options...
Gaz1858 Posted January 22, 2010 Share Posted January 22, 2010 Each unit can only fire at one target regardless of number of guns. This applies to infantry and tanks alike. This is only overriden by any special rules a unit may have, such as the POTMS mentioned earlier. Link to comment Share on other sites More sharing options...
Koremu Posted January 22, 2010 Share Posted January 22, 2010 It's worth noting that a Hurricane Bolter sponson is one weapon system, not 3 (or 6!) In fact I can't think of a single tank with multiple weapons on a sponson... Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted January 23, 2010 Share Posted January 23, 2010 It's worth noting that a Hurricane Bolter sponson is one weapon system, not 3 (or 6!) In fact I can't think of a single tank with multiple weapons on a sponson... there is landraider with two twinlinked heavy bolters in each sponson, but I think thats apoc/forgeworld. Link to comment Share on other sites More sharing options...
Leonaides Posted January 24, 2010 Share Posted January 24, 2010 Or the Baneblade (or variants), with HB sponsons topped with a lascannon (or something)... Link to comment Share on other sites More sharing options...
Marshal Hadrarius Posted January 24, 2010 Share Posted January 24, 2010 Bit of topic but the razorback turret with twin linked plasma and lasscannon counts as 2 wpn systems :) not a sponsoon i know just thought i'd put it out there. Link to comment Share on other sites More sharing options...
