Wolves, vs necron
Ladislao
Hello fellow berothers... i did not play the wolves for a time, but i ve been challenged by a necron player, and the challenge must be met
He usualy play something like this: 3 units of warrior, a monolith, a necron lord on...the flyng thing, a noctifer and 3 ghosts
I was thinking to bring something like this...
1 pradatorr ( 2 laser and auto cannon ) 6 long fangs (2 laser and 3 missile launchers) with a laser razzorback, 2 squad of 9 gh+ the wolf guard on ryno. 5 spare gray hunters ( they will ride the razzorback) and a rune priest..
this will be the core, and i have 500this points left.. and i need something to fight back the nightbringer... i m not sure to be able to kill it with fire only...
I was thinking about a land raider full of something, but wich one? Taking away something from the list, i can have a quite wull pack of blood claw with arjak.. i will lose a lot of man, but i shloud be able to crush it...
Another idea was ragnar + blood claws/gray hunters... charging at i 5 and s 5 will grant me the possibility to wound it before taking any real damage... but it's costy!!
do you have any idea or advice?
https://bolterandchainsword.com/topic/190535-wolves-vs-necron/
http://www.bolterandchainsword.com/index.p...howtopic=190011 hope that gives you some insight
Power Weapons! Wolf Guard Terminators! Long Fangs with plasma cannons, and get into close combat with your Grey Hunters! stay in cover from his guns, watch out for his Destroyer Lord. Use the predator's Lascannon's to take out Lith, it can be ignored but it can also be annoying. And consider using Wolf Scouts! going behind enemy lines can be a pain for Necrons, especially once you get into combat. Sorry I'm in a rush.. so I'm just writing things as I go. Good luck!
I have always owned Necrons till resently. I got beat by them. (cry) It happens. Bad dice roll and he set up amazing.
The trick is focused fire. Make sure each squad is down completely and no lord nearby with an orb to make them get back up. Kill everything in a squad and they can not come back. They need one of the same type in 12 inches? Maybe 6"? I can't remember DOH! Regardless focus on the easy stuff and he will phaze out. It's easy reallty.
I know his weapon allows no saves. So maybe a wolf Lord with Saga of the bear. So he can be stabbed a few times before he goes.
My ork buddy had an ork with a claw that killed Night bringer 2 times before. So now he has a scyth from him in one hand.
Plasma cannons are you friend. Tricked out GH packs are you friend. Kill a ton where most will not be in range to rez and they will have to be removed. Hope that helped.
