just infiltrate them within 18 inches of the long fangs
with all sw runing RP with choser ?
and you can rain plasma on them from turn one
the deployment is more then 18" if visible or 12" if no los can be drawn . no los is hard to do and on top of that harder to pull off when playing against choser. 18" means you move 6" and the range between you and the LF even if he put them on the very edge of his deployment [only why would a SW do that. his RL and LC have range bigger then 36"] , the range is still 12"+ smallest range known to man , but still bigger then 12" . so next turn those 15 chosen eat what ever can be shot at them or end up contered in hth.
plasma chosen 18" away bad idea. trying to base unit effectivness around infiltration against SW another bad idea.
https://bolterandchainsword.com/topic/190574-chosen/page/3/#findComment-2425432
