GKT assembly and painting
Malus the Destroyer
  • 2 weeks later...
The nice thing about Grey Knights is that they don't hold anything across the chest, or in other positions that cover important places. Thus, painting after assembly is perfectly acceptable.
However, my Grey Knights are so heavily modified that painting after assembly simply is not possible - everything has to be in the right place at the right angle and all the gaps must be mended and smoothed with putty, before any primer ever touches the metal. It is difficult to assemble after painting, because the glues and putties will adhere to the paint instead of the metal and can therefore be easily pried apart. Assembly after painting is much easier with plastic, as the plastic glue simply eats through the paint and binds it along with everything else, though I can't really do this because I tend to use a little too much plastic glue.
I did my terminators speratly to get a nicer paint job (I'm not that good so I find that if I can do things slowly and seperatly I can get really nice paint jobs)
The problem with painting GK's when assembled to me it that, because their metal I find that my style of painting (Rough) tends to break the models so I think it sort of depends on you painting style
