Power Fists
theonelawler
Only if you are equiped with a difference special close combat weapon, such as a power weapon or frost blade- NOT if you just feel like it, or are only otherwise armed with a SS, CCW, or Pistol.
4rth Edition had optional use of Special Weapons- no more.
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2270375
I believe that in 5th you are no longer able to "turn off" a special CCW. In 4th you could use any special CCW as a standard CCW.
At least, that's what I remember someone saying. On a quick check thru the SCCW rules I see no provision for it. But I could be wrong, since I can't give a specific page number disallowing it.
Edited to say: dang, beaten to the punch. That's what I get for actually looking up the rule to make sure I'm not talking out of my rear.
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2270379
Nah, this one crops up in the OR forum about once a month, so Ive had it drilled into my head.
Rending isnt a SCCW, its a special rule... so you cant choose their either- the SCCWs rules automatically take preference I believe, even when facing creatures its not an advantage with- Wraithlords.
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2270413
I just don't see how you can't choose, it's like having to fire your plasma gun because the rest of the squad is firing. Really, if you wanted to, could you choose not to attack at all if you really wanted to lose combat? I looked through the rule book and can't see where it says you must use your SCCWs. It's like if you had 3 CCWs you should be able to choose which one you utilize.....
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2270483
I admit we should have the choice, but I also understand this limitation from the designers perspective.
I think its there to make the game closer to realistic situations. If you ask Superhuman Vikings in Power Armour to charge something, its to kill it, not ''to get entangled in combat in order to not be shot in the following shooting phase''...
Its hard for me to see how a sergeant wouldnt use its powerfist to blow the enemys heads, after seeing them killing one or two of his battle brothers.
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2270649
page 42
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2270710
I see that, but give him his 1 atack with his boltpistol on I and normal strength and the fist attacks after that, he has 2 hands and 1 has a pistol ready to hit or shoot, hes not going to not use that hand
That would be cool... though how to deal with plasma pistols etc might get confusing for some people.....
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2271053
Page 42. If you attack in combat and are equipped with a Special CCW you MUST use that weapon. If you have 2 SCCW then you must use one of them, but you will not gain a bonus attack for having 2 CCW.
Okay, I'm not trying to beat a dead horse here, but I'm assuming you're looking at the bottom right on pg 42, where if you have 2 different special weapons you must choose which weapon to use. Unless there is a different section you're looking at that I'm not seeing. The normal & special weapon section talks about all of the weapons benefitting from the special weapon....I don't know, I've played that you can choose and I'm still not 100% that you can't.
The advantage for not using the PF or TH is to hit at I instead of gaining the S bonus, for a strategic advantage not in an attempt to remain in CC, so it would be in the spirit of the game, not to be cheesy.
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2271478
Actually what is is that if you have a SCCW, you get the effects- period. Nowhere does it say you can choose Not to use its effects, or choose to use just a normal CCW instead.... thus you cant be cause 40k is a permissive rules set.
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2271544
Hehe, I can just see it. "Damn, my vox is out again. It sounded like Sarge just told us to turn off our power axes!"
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2271719
'Ok guys heres the plan. we run in real quiet like and stand right next to the carnifex. Now their vision is based on movement so as long as we stay real still once we're there and nobody does anything stupid like attack him, yes frank i mean you, then we should be alright.'
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2272060
LEEEEEEEEEEEEEEROOOOOOOOOY JEEEEEEEEEEEEEENKIIIIIIIIIIINSSSSSSSS!!!!!
*achem*
~O
https://bolterandchainsword.com/topic/191372-power-fists/#findComment-2272110
