Saga of the Beastslayer Question
Level
My appologies if this has already come up somewhere but I couldn't find anything with the search.
The codex states under saga of the Beastslayer thata charachter with this saga can reroll failed to hit rolls against walkers, MCs and toughness 5 models.
Simply put there is nothing stating that this is only in CC.
I just assumed that it would be hand to hand fighting rerolls only but do you think that a Rune Priest with Living Lightning and a chooser could reroll missed BS 5 shots against the above mentioned targets or am I pushing my luck here?
cheers
Level
https://bolterandchainsword.com/topic/191389-saga-of-the-beastslayer-question/
I think it's intended for CC only, but if you look at it, it is both. Which is awesome, and makes sense, since a beastslayer would need to know where to aim for the right spots in bringing down them beasties worthy of sagas in both shooting and hand-to-hand. That being said, this just makes Living Lightning even more lethal.
But You don't need to roll to hit for psychic shooting power!
Yes, you do.
And yes, it does. Rune Priest w/ Living Lighting, Storm Caller Master of the Runes and Beastslayer is very nice, especially if you face some T5 armies (Death Guard, Nurgle Daemons, some Nid forces etc.)
not all powers need a to hit roll, with space wolves the following would- living lightning and fury of the wolf spirits.
the others don't but if they are shooting attacks require all he other criteria to be met.
if the power requires a to hit roll then saga of the beastslayer would allow re-rolls to hit.
other attacks, ranged or otherwise would also be subject to the re-rolls granted by the saga.
Wow, I think that the Saga of the Beastslayer on a LL Rune priest just became 15 points of Awesome.
Thanks guys
10 points.
And also I think PP is a viable option, because with BS 5, You are re-rolling those pesky "get's hot"- "1" rolls, instead of taking armor saves. Providing You shot plasma at MC, walker etc.
Re-roll is BS 6
Or a special rule like twinlinked, etc.
Edit: I feel its worth noting that a Wolf Priests Oath of War does NOT work for shooting attacks, only CC.
However Ulric´s oath works in both... right?
Yes, since it operates under an entirely different and self contained rule.
Wow, never noticed either of those things. I assumed it was for CC only. Hmm, does Ulric in a bunch of Long Fangs sound wierd? Good bye, TMCs!
That's quite a cunning strategy, considering I find taking the saga with a character thrown in with Blood Claws/Hunters fairly useless because they don't go after big things, but four Long Fangs with missile launchers and a multi-melta with re-rolls could be fun. Plus he can crush skulls if someone decides to have a go.
but if your shooting one MC with T6 , you ARE allocating your attacks to hit and to wound rolls on that model , it should still work ? Its like how the FAQ for Arjack with his targetting rules , if majority is T5 or above it still works ?
Obviously ther problem with the wording here and other rules related is that it doesnt stat its CC attack or shooting attack , dues we can assume its both
Well, that's a good point, Although the text specifies "model". I suppose if a majority in the unit were T5+ then you could get the rerolls... I think there are those that would argue against it, though.
I wish GW would quit writing such fuzzy rules.
There are few instances where a single model will have T5 and the rest of the unit will have a lower toughness... Ork Warbosses, Tyranid Primes.... and maybe a biker HQ thats in a unit of infantry for a MEQ army. Ooo and Cassius.
Against Monstrous Creatures though we know were good, as they can never join a unit anyways, save Tyrant Gaurd wich are T 6 anyways.
