Brass Etch symbols
MagneticFreak
Hello all,
I was wondering if any of you had some experience with the brass etched Forge World symbols. They look fantastic, but are they worth it? Can they be bended to fit on shoulder plates?
for those who are wondering what I might be talking about: Brass etched symbols
many thanks
https://bolterandchainsword.com/topic/191919-brass-etch-symbols/
I got these. They are very handy for adding "official" seals and such.
They can be bent to go around shoulder pads. they are VERY thin, and will easily bend. The only problem is with some of the rune ones, the actual runes are so thinly etched that I have trouble painting them because even the washes barely show. The symbols are all top-notch though.
I got two SW sprues when I started my Greatcompany on last years GD, currently my GC runs at 12.5k and I still have some left. I love them!!! Some sides can be sharp, just check carefully. As to the Symbols, the "rune-licenseplates" are great for both vehicles, dreads and TDA Shoulderpads. Generally I use the hairdryer to heat them up a little, and then bend them over whatever surface I want them on in the end. Be careful with the heating, don't overdo it ;) .
The Crosses are tricky, best put them on even surfaces, they arent't really fit for shoulderpads and the like, in my opinion.
As for the painting, after priming, I drybrush Dwarf Bronze(if some gets into the fine runes, just brush in the direction of the rune with a clean brush and it comes out)-then I add Baal Red Wash and finish with another light drybrushing with DB, works for me.
There's this nice Wolf stalking, used him for the LR sides, awesome!You can even work some GS on them to make them more 3D like.
Hope that helps.
I bought a set a while ago and they're great. Personally, I don't paint them. Once the model is painted I just glue them on with crazy glue. IMO, they look great as is.
The only ones I'd consider painting are those with larger areas that have been etched. The tarnish is uneven and I don't like the look too much. But other then that, they don't need painting.
