theonelawler Posted February 10, 2010 Share Posted February 10, 2010 First does the -1 to initiative from thunder hammers stack? and second how does BS 6 and twin-link work? Link to comment https://bolterandchainsword.com/topic/192185-quick-rules/ Share on other sites More sharing options...
Spacefrisian Posted February 10, 2010 Share Posted February 10, 2010 Its not -1 Iniative, Its you strike at Iniative 1 with a Thunderhammer. Bs6 allows you to re-roll hitting on a 6. Twinlinked allows you to re-roll hitting on a 2+. Hope that helps. Link to comment https://bolterandchainsword.com/topic/192185-quick-rules/#findComment-2281179 Share on other sites More sharing options...
theonelawler Posted February 10, 2010 Author Share Posted February 10, 2010 sorry got the Thunderhammer wrong. but with bs6 and twin-linked do you roll to hit +2 twin linked+2 then one or two +6 to hit or to hit +2 to hit +6 and then twin linked +2 and to hit +6? Link to comment https://bolterandchainsword.com/topic/192185-quick-rules/#findComment-2281184 Share on other sites More sharing options...
Rider-75 Posted February 10, 2010 Share Posted February 10, 2010 you can only ever reroll a dice once. ie: use the 2+ reroll from the twinlink, rather than the 6 from the BS. Link to comment https://bolterandchainsword.com/topic/192185-quick-rules/#findComment-2281213 Share on other sites More sharing options...
theonelawler Posted February 10, 2010 Author Share Posted February 10, 2010 ok thank you for the help. Link to comment https://bolterandchainsword.com/topic/192185-quick-rules/#findComment-2281219 Share on other sites More sharing options...
Schertenleib Posted February 10, 2010 Share Posted February 10, 2010 So if you roll to hit and get a one you don't get to re-roll twin-linked weapons? Link to comment https://bolterandchainsword.com/topic/192185-quick-rules/#findComment-2281507 Share on other sites More sharing options...
DV8 Posted February 10, 2010 Share Posted February 10, 2010 So if you roll to hit and get a one you don't get to re-roll twin-linked weapons? No, you pick either or. Having BS6+ grants a re-roll, but with negative modifiers. So with BS6, if you roll a 1, you can reroll the To-Hit roll, but this time needing a 6 instead of 2+. Having Twin-Linked means you re-roll your to-hit roll, but you can never re-roll a dice more than once. So in this instance you have a choice of either hitting on 2+, rerolling on 2, or hitting on 2+, and then rerolling on a 6 if you miss. Obviously you take twin-linking 2+, and not 2+/6+. DV8 Link to comment https://bolterandchainsword.com/topic/192185-quick-rules/#findComment-2281521 Share on other sites More sharing options...
Ullr Direfang Posted February 11, 2010 Share Posted February 11, 2010 if a weapon allows a re-roll(twinlinked) then you get no bonus for having a BS of higher then 5. Link to comment https://bolterandchainsword.com/topic/192185-quick-rules/#findComment-2282175 Share on other sites More sharing options...
Xeenos Posted February 11, 2010 Share Posted February 11, 2010 take a look at page 18 of your rule book, top left corner. That explains how BS 6-10 works. Link to comment https://bolterandchainsword.com/topic/192185-quick-rules/#findComment-2282466 Share on other sites More sharing options...
