Gene Seed: A Brief Guide
Ferrata
Whilst there is no background saying when they stopped using BA/DA gene-seed (or at least slowed down); it stands to reason that it would have been early on instead of later. You could guestimate that around the time of the 13th Founding it would have decreased.
Tyrak you have read my mind. There will be a section on non-standard gene seed in the larger article - so mixed, traitor, records lost etc.
Does this mean information on the geneseeds as used by the traitors, or the geneseeds of the original traitor legions stocked by the AdMech?
I'm just wondering, since information on either or both could be very useful for aspiring IT writers.
It was more the discussion about using Traitor gene-seed or not, I doubt I'm going to go into the detail I am with the Loyalists. Why? Because the AdMech does not use Traitor-seed to make new chapters. Simple as. Even those who are writing an IT will either be of normal gene-seed or a splinter from the original Legion, and then it gets a lot more complicated and gene-seed generally goes out the window.
