Hrothgar Beastslayer Posted February 14, 2010 Share Posted February 14, 2010 before you say anything i did use the search function and found nothing. Now, here the Senario, Wolf lord on Thunderwolf with 2 frost axes, does this make him strength 7? I didnt see anything in the FAQ or the rule book, it says that a model armed with 2 special close combat weapons gets +1 attack along with any bonuses those weapons confer (or close too that) Also i won a canis wolfborn model in a tournement today and have come up with a wolf lord setup, lord-TWM-Belt of russ-2 frost weapons-wolf tooth necklace and maybe a saga. thoughts? Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/ Share on other sites More sharing options...
Jarl Kjaran Coldheart Posted February 14, 2010 Share Posted February 14, 2010 this is debated here on the forums, i would say no myself. WLK Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2285503 Share on other sites More sharing options...
DV8 Posted February 14, 2010 Share Posted February 14, 2010 You can only use 1 special close combat weapon and gain its benefits. The other, if eligible, simply gives you +1 Attack. Example, Wolf Claw and Frost Blade. You do not get +1 Strength and re-roll wounds. You get either or. DV8 Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2285512 Share on other sites More sharing options...
Hrothgar Beastslayer Posted February 14, 2010 Author Share Posted February 14, 2010 Yes but it says that 2 Different special cc weapons you have to choose which one to use. these would be under 2 of the same special weapons that says you get +1 attack and all bonuses normally given Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2285519 Share on other sites More sharing options...
Ullr Direfang Posted February 14, 2010 Share Posted February 14, 2010 ...................................................................................(*face palm*)................................................................. Page 82 of the rule book: Two of the SAME special weapons: the model gains one additional attack. all of their attacks, including the bonus attack, benefit from the special weapon's(this is were it specifies that the bonus for the weapon type apply not both weapons together) bonuses and penalties. so you get +1 S for the mount, +1 S for a frost weapon, and +1 attack for two frost weapons...... Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2285524 Share on other sites More sharing options...
Wildfire Posted February 14, 2010 Share Posted February 14, 2010 That is referring to the primary special weapon used, not to the one not used. It's simply saying that the extra attack does not use the secondary weapon's profile. Or do you believe that a model with two power fists strikes at S16? Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2285720 Share on other sites More sharing options...
Grey Mage Posted February 14, 2010 Share Posted February 14, 2010 Yes but it says that 2 Different special cc weapons you have to choose which one to use. these would be under 2 of the same special weapons that says you get +1 attack and all bonuses normally given Yes- but its pretty explicit about you only getting the bonus once. As pointed out by Master Direfang, its a possessive s, not a plural s, and thus refers to the bonus given by that type of weapon, not the the bonuses provided by multiple weapons. Example: a pair of PFs gives you +1 A at str 8, not +1 A at str 10. Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2285743 Share on other sites More sharing options...
Kjarl Grimblood Posted February 14, 2010 Share Posted February 14, 2010 NO NO NO! You cannot do this. Read your rulebook and stop trying to twist the rules. The rules are perfectly clear on this point, see page 82 of the rulebook. Learn to play fair. Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2285986 Share on other sites More sharing options...
Hrothgar Beastslayer Posted February 14, 2010 Author Share Posted February 14, 2010 How am i trying to cheat? I was simply asking about a rule i thought was valid. Im not twisting the rules, just asking about one. i did read the rulebook and misinterpereted it. Thank you for answering. Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2286024 Share on other sites More sharing options...
Spacefrisian Posted February 14, 2010 Share Posted February 14, 2010 Just stick with one frost blade and you should be fine. Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2286033 Share on other sites More sharing options...
Hfran Morkai Posted February 14, 2010 Share Posted February 14, 2010 A Strength 6 Wolf Lord (Using TWM and a Frost Blade) still shouldn't be sniffed at, it's nasty. Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2286035 Share on other sites More sharing options...
Hrothgar Beastslayer Posted February 14, 2010 Author Share Posted February 14, 2010 I agree, im going to be using him with a storm shield, frost blade, TWM, Saga of beastslayer maybe and wolf necklace. Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2286142 Share on other sites More sharing options...
Coverfire Posted February 14, 2010 Share Posted February 14, 2010 I agree, im going to be using him with a storm shield, frost blade, TWM, Saga of beastslayer maybe and wolf necklace. Give him a Wolf Tail Talisman too. Wolf Tooth Necklace on a Wolf Lord might be a waste of points but if you can spare it then take it. Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2286189 Share on other sites More sharing options...
Oldenhaller Posted February 15, 2010 Share Posted February 15, 2010 more to the point...search function is fine but theres a faq for a reason...so make sure you check here first ~O Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2286398 Share on other sites More sharing options...
Ullr Direfang Posted February 15, 2010 Share Posted February 15, 2010 more to the point...search function is fine but theres a faq for a reason...so make sure you check here first ~O i find it funny that the FAQ you mention tends to be in the top 5 for almost every search..... Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2286427 Share on other sites More sharing options...
Oldenhaller Posted February 15, 2010 Share Posted February 15, 2010 all about looking at the top of the page......or using the right terms i guess? ~O Link to comment https://bolterandchainsword.com/topic/192496-duel-frost-weapons-i-know/#findComment-2286434 Share on other sites More sharing options...
