Wolf Lord Challenge entry - finally finished
DGC
Many moons have passed since I signed up for the Wolf Lord challenge but I have finally completed 'Young Logan'. Hope you like
W.I.P shots
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0864.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0865.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0867.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0870.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0875.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0873.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0872.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0871.jpg
Finally finished shots
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0902.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0904.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0903.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0905.jpg
http://i149.photobucket.com/albums/s47/DGC_album/Young%20Logan/DSCN0906.jpg
As my penance - sort of, I will have him lead my first game using the new dex in a couple of weeks time without a body guard - just to prove he is as bad ass as he claims
C&Cs welcome, just sorry it took so long
For Russ
DGC
Thanks to all for the positives ;)
A quick parts guide;
The axe is the original axe head and collar from the metal Logan model with a piece of brass rod for the shaft. Added some GS detail to the shaft and a plastic rivet for the 'activating' button. The handle is from one of the SW sprues as is the wolf head ornament on the end.
The torso is from the regular terminator box set with all the detail filed off and some GS wolf teeth and a plastic wolf skull taken from the new SW sprues (I think it was from the drinking horn piece). When I first did it I added the runic strip on the chest but when I added the fur it all got covered. You may also see that in two pics the wolf's tooth necklace is different, I made one but wasn't happy so I did it again. The head is from new SW plastics with some GS hair and 'tash extensions. Hair braids are from other heads and blended in with more GS.
The storm bolter arm was made from a regular terminator one holding a weapon. The weapon was removed from the top of the hand and the lower bit was cut flush with the fist. The storm bolter is from the new SW termies sprue with the hand grip and magazine removed - this was then side mounted. To finish it off a small plastic rivet was added to the top centre of the hand as a trigger button and a small slice of plastic card was added to the join between the bolter and magazine to visually try and join the parts together.
The wolf's head was cut from the one on the new SW termie sprue and the cloak was made using a base skeleton of GS with some GS claws made seperately and all left to dry. The fur it's self is made using 'Pro-create' putty, (a first for me) textured using the GW skulpting tool. I glued the claws in place then added the fur in two or three sections allowing each one to cure slightly and the dragging and flicking the putty starting from the outside edges inwards. Quite happy how this turned out but could be neater so I will practice some more and try to develope the method.
The base is kept simple to tie it in with the rest of my army - just some bark chippings and sand painted up
For Russ
DGC
