[SH] Does the heavy flamer hurt terminators?
Commander Sasha
EDIT: There MAY be the possibility that you can't shoot the section you're in.
This is true. The flamer cannot fire at the section he is in, however if he catches a fellow terminator in another section, he is killed on a 2+. Can change the way you look as suicide mission quite a bit when you realise you can sacrifice a marine to get the job done a touch faster.
